[Solved] Softkeys hook.itm problem
13 replies to this topic
#1 OFFLINE   vaidasbar
vaidasbar
  • 19 posts
    • Time Online: 1d 16h 39m
Posted 14 March 2013 - 12:00
Hi,
1. i dowlnoaded right_softkey_hook.itm from SE Elm by Duals (http://www.sonyerics...odyfikacje-elm/)
2. put file in tpa/preset/custom
3. uploaded blank customize_upgrade.xml to tpa/preset/cutom
And the softkey left the origin.  :(
Also make Master Reset (settings only), no success.
My phone is Elm r7ca061 red cid 81
I googled other forums, there is the same instruction everywhere.
Can anyone help me? :unsure:
#2 OFFLINE   sonyman
sonyman
  • 309 posts
    • Time Online: 13d 7h 54m
Posted 14 March 2013 - 16:54
try other customize upgrade. Did you have progres bar on the first run after added softkeys?
#3 OFFLINE   vaidasbar
vaidasbar
  • 19 posts
Posted 15 March 2013 - 06:42
Customize_upgrade is blank, no text inside.
Yes, there was progres bar at startup.
#4 OFFLINE   Carlito Brigante
Carlito Brigante
  • 37 posts
    • Time Online: 1d 13h 37m
Posted 15 March 2013 - 15:48
i think it's doesn't matter but update your software to R7CA065 and try again.
#5 OFFLINE   vaidasbar
vaidasbar
  • 19 posts
Posted 15 March 2013 - 17:54
In my area r7ca061 is the latest fw. Any other suggestions?
#6 OFFLINE   bartolinio3
Posted 15 March 2013 - 20:30
Try to delete all files from tpa/preset/system/custmenu :)
#7 OFFLINE   vaidasbar
vaidasbar
  • 19 posts
Posted 16 March 2013 - 10:19
There is no such folder at all.
Custmenu folder i founded in system/preset/custmenu (not tpa/preset/system), but it has many folders containing xml files in each. I wouldnt dare to delete its content.
#8 OFFLINE   vaidasbar
vaidasbar
  • 19 posts
Posted 19 March 2013 - 07:00
Please, somebody help me. I see many Elm users made softkeys change. I want it too :)
#9 OFFLINE   not found
Posted 19 March 2013 - 07:33
Bartolinio3, maybe you actually meant
Vaidasbar, upload softkeys to
tpa/preset/custom
then delete cust_menu_data.dat and cust_menu_done_unpacking.dat from
#10 OFFLINE   vaidasbar
vaidasbar
  • 19 posts
Posted 19 March 2013 - 15:13
Not found, i did as you said. Nothing happened. Softkeys left unchanged :(
Maybe it is because i copy files using java app?
#11 OFFLINE   not found
Posted 19 March 2013 - 17:58
Use FAR manager with SEFP2 plugin :)
#12 OFFLINE   bartolinio3
Posted 19 March 2013 - 19:23
Yes, you're right. Thank you for correcting :)
vaidasbar - How did you put the right softkey? With java app too? Does it work right? Try to put left softkey with Far + SEFP as not found say ;) After that turn on the phone, wait progressbar and turn the phone off. Next with the Far + SEFP go to system/preset/custmenu and delete files that pointed not found.
#13 OFFLINE   vaidasbar
vaidasbar
  • 19 posts
Posted 20 March 2013 - 18:27
It works :D
The problem was that code in customise_upgrade.xml was not correct. It was the first line unnecessary.
Thanks guys :)
Edited by vaidasbar, 30 March 2013 - 08:38.
#14 OFFLINE   not found
Posted 20 March 2013 - 20:24
Welcome ;)
That problem has been solved and thread is closed. If you have any other questions, please start a new thread. If you have any complains / opinions / suggestions, you are welcome to send them to Sony Ericsson World Team using Private Message.
