Good morning to everibody
I would like to mod an Xperia pro with inductive charging ( with a wireless mat)
I'm not a techician, but in internet is available many kits for samsung
I would like to try to use one of that kits
the only problem for me is to know if there are any connection available in the bottom part of the
mobile covered, in the service manual are called USB contact in the antenna unit PBA,
where is possible to connect to the general supply feeding of the usb port ( instead solder on the mini connector in the top ) .
Have anyone an idea or suggestion ?
Thanks in advance for your reply
regards
wireless charging - Inductive charging mod
Started by penpaolo, Jan 13 2014 12:59
