W580 R8BE001 Patche | Patches
#1 OFFLINE   Adogard
Adogard
  • 503 posts
    • Time Online: 14d 17h 37m
Posted 08 September 2011 - 12:20
Tak jak w temacie, dodajemy tylko patche. Komentarze i pogaduchy beda nagradzane :)
Spis patchy | List of patches
Ability to cancel the sending of SMS-message
Ability to enable  disable deleting messages
Ability to run Deskbar elf's Gui by menu.ml (event 0x3010)
Ability to set the radio on full screen and back
Ability to turn On / Off file transfer
Ability to turn On / Off file transfer v.2
Add free heap in shutdown menu
Adding icons in Notes
Add icons to navigation keys in "Shortcuts (Links)" menu
Add information about mp3
Add item "Record" to the Radio
Add item "Recorded sounds" for showing your Recorded sounds
Add option to set current track as a ringtone
Add softkey, which allows you to pause music playback in the file manager v. 2.0
Add the ability to automatically choose the first USB mode when connecting the cable v.1.0
Add to QuickAccess menu items: "To Standby" and "Close all running Java"
Add to receiving MMS softkey "OK"
Added 2 points in the function of 5 tab
Add-On "BLEplayer.elf"
Addon for the patch "Copy/Move files to any folder (v.7 © IronMaster)"
Addon for the patch "Privacy" v3.0 from IronMaster
Advanced snooze alarm
Auto power off your player and radio
Automatic recording of Voice Call
Automatic shut off Bluetooth over a given time
BlackBerry List Menu (BBLM) v.1.0 Beta test
Blacklist Reject mode v.1.0
Capturing screenshots with button 5
Change file information v. 2
Change GUI of call status
Change GUI of SMS editor
Change Gui of startup menu to fullscreen
Change list menu GUI
Change On/Off menu style v.1 fix mod v.1.5
Change systems fonts
Change the time of drawing in mediaplayer
Change type of menu On / Off
Change way of showing Activity Menu
Changing Operator Logo v. 1.0 beta
Changing the size of the system font. Is made smaller - IMHO very convenient!
Clear Lock / Unlock keyboard (* + right soft) v2
ClearBass Equalizer add-on
Close Radio when pressing button Back, minimize Radio when pressing "Long Back" v.2
Choose menu style
Delete "Games", "My applications" from file manager
Delete label "Minimize" in Walkman (unnecesary label)
Delete/Change items (label) in "Phone status" v.1
Disable prompt to update the time
Disable reject with double press volume keys for incoming call
Disable setup wizard when changing SIM-card
Disables STARTUP_IMAGE, SHUTDOWN_IMAGE and STARTUP_SOUND.mid v.2
Displays the show/hide phone number status in the system tray
Do not display the "My Devices" when searching for Bluetooth devices if they are not in sight v.1.2
Easy Words Backup
Equalizer border color level
Enable the transfer of java-applications
FeedbackTicker Mod v. 2
File Manager Shortcuts v. 1.1
Fixing the phone password verification if there is no SIM-card
Flash THM v. 1.9 fix
Full screen Walkman
Fully operational phone without a SIM-card
Heap shift! More stability for patches! v.64k
Hide Window "All contents of the Memory Stick will be deleted! Format?"
If you switch to landscape mode image icons are hiding themselves
ifs/settings/acoustic -> card/other/drv/snd ifs/settings/camera -> card/other/drv/cam
In the "Silent" a Video Player and Radio not working
Information about voltage and temperature
Keylock and sleepmode at the end of the voice conversations
Keys work in message "Phone ready to be used with computer"
Melody for unknown and hidden call
MiniGPS v1.0
More lines in SMS Editor
Move characters and smiles in table v.1.2
Moving Track Info bar
Office of the player v.2.2
Office player and radio through the headset v.4
On/off hours images by pressing the joystick in Sleepmode v. 1
On/Off Keyboard Backlight
Phone password when entering QuickAccess Menu v.1
Phone without SIM card
Playing sound file when start-up menu appears
Possibility to store more SMS (was 1000)
Radio without headsets
Recording with .mp3 file format
Remove java security restrictions
Remove message Saved in Drafts
Remove messages "Quick charging" and "Fully charged"
Remove the restriction on the transfer of files in the File Manager in "Flight Mode" switched off Bluetooth v.1.0 fix
Remove voice recorder beep
Replace the large icons. Mp3 on the cover of the track
Replacing folder to save screenshots from the video v.2
Replacing the background while watching videos in vertical mode
Replacing the phone graphics v.2
Reversed colors in sleepmode
RF on/off reject mode with hold button "back" when incomming call
Screensaver at the end of the voice conversations
Select item with numeric keys in USB Connection Menu
Selection of menu style
Set a password to access the window of alarm clock
Set display brightness according to time and battery level v1.1
Setting the display brightness in voice conversations v.1.5
Setting the menu in landscape mode
Show full text in "View all labels" of "ServiceMenuBook" v. 1.1
Show main menu in full screen v.1
Short vibration when entering message "Sony Ericsson ROCKS!" v.1.1
Short vibrations when playing a video in Video Player or File Manager
Sleepmode when pressing Volume +. Keylock when you press the Volume -
SMS Transliter v2.0 RU
Switching to more than 2 input languages with a key #
System font become italic
Turn On/Off Bluetooth
Turn off color diods (no bug!)
Vibration when entering Equalizer on MediaPlayer
Vibra in 55 th second of each minute in a call
Vibra Music v. 1.1
Vibra when entering Quick Acces Menu On/Off
Vibra when switching to a new track (only when the new track indicator is displayed)
Walkman Key as Play/Pause button
;W580 SW-R8BE001
;Change Gui of startup menu to fullscreen
;Removed softkeys
;v1.0
;© Mojsa
;® MaPkiZzz aka Vital
;(p) miguel8e
452C031A: 206800215EF093F82068 014F3847C046D1BECF45
45CFBED0: 00000000000000000000000000000000 0421206800F00AF82068002100F008F8
45CFBEE0: 00000000000000000000000000000000 206800F007F82068064F3847024F3847
45CFBEF0: 00000000000000000000000000000000 024F3847024F3847E94E364549E43145
45CFBF00: 0000000000000000 851A38452B032C45
;W580 SW-R8BE001
;Add item "Record" to the Radio
;save to other/fm.amr
;(c) 2007KrasH
;(p) UltraShot
450f8a7e: A0692A1C391C88F23CFE 01480047FFFF311ACF45
45cf1a30: 00000000000000000000000000000000 2E4A1121A06900F02FF82D4A1121A069
45cf1a40: 00000000000000000000000000000000 00F02CF8A0692A1C391C00F025F8264B
45cf1a50: 00000000000000000000000000000000 1847FFB5041C00F023F8071C1BD00021
45cf1a60: 00000000000000000000000000000000 C943381C00F01EF80121381C00F01CF8
45cf1a70: 00000000000000000000000000000000 20496158381C00F019F81FA1381C00F0
45cf1a80: 00000000000000000000000000000000 17F823A1381C00F015F8381C00F014F8
45cf1a90: 00000000000000000000000000000000 381C00F013F8FFBD094B1847094B1847
45cf1aa0: 00000000000000000000000000000000 094B1847094B1847094B1847094B1847
45cf1ab0: 00000000000000000000000000000000 094B1847094B1847094B1847094B1847
45cf1ac0: 00000000000000000000000000000000 01173845791738450575F544A575F544
45cf1ad0: 00000000000000000000000000000000 D175F5448176F544E575F5440176F544
45cf1ae0: 00000000000000000000000000000000 9576F5447D75F544898A0F45531ACF45
45cf1af0: 00000000000000000000000000000000 D30300003C0300002F00630061007200
45cf1b00: 00000000000000000000000000000000 64002F006F0074006800650072000000
45cf1b10: 0000000000000000000000000000 66006D002E0061006D0072000000
;W580 SW-R8BE001
;Vibra when switching to a new track (only when the new track indicator is displayed)
;Choosing to show/not show indicator
;© 2007KrasH
;(e) jamesbond22
;(p) Ospi
452B89A6: 00F029F8 C046C046;remove indicator
452B899E: A069 8847
452B89B0: BBEC0000 6105CE45
45ce0560: 00000000000000000000000000000000 0B49A069FFB5002081B00090A2B06846
45ce0570: 00000000 06498847
45ce0578: 0000000000000000 32220B1C0668FF24
45ce0580: 00000000000000000000000000000000 69343659B04723B0FFBDFFFFD51C2E45
45ce0590: 00000000 64EC0000
;Time of vibration:
45ce0574: 00000000 FF212D31;vibra - 0,3 s.
;45ce0574: 00000000 4B21C900;vibra - 0,6 s.
;45ce0574: 00000000 7D21C900;vibra - 1,0 s
;W580 SW-R8BE001
;Show main menu in full screen
;Removed softkeys
;v1.0
; ©Mojsa
;(P) Ospi
4538628E: 0121201CDEF729FE377B 014B1847FFFF51012944
44290150: 00000000000000000000000000000000 0421201C377B00F009F8201C00F008F8
44290160: 00000000000000000000000000000000 201C00F007F8201C064B1847024B1847
44290170: 00000000000000000000000000000000 024B1847024B1847E94E36459D1A3845
44290180: 0000000000000000 851A384597623845
;W580 R8BE001
;Playing sound file when start-up menu appears
;© jamesbond22
;(p) Pakoko
452b88aa: 0020 8847
452b8908: 4482BA45 11C0CF45
45cfc010: 0000000000000000 03490020FFB502D1
45cfc018: 0000 001D
45cfc01a: 0000000000000000000000000000 024FB847FFBD4482BA45E1470045
;ID:
;0x01 :"request",
;0x02 :"success",
;0x03 :"connecting",
;0x05 :"registered",
;0x06 :"retrysuccess",
;0x07 :"failure",
;0x08 :"progress",
;0x09 :"messageclick",
;0x0A :"notification",
;0x0B :"reminder",
;0x0C :"disconnected",
;0x0D :"minuteminder",
;0x0E :"discreet",
;0x0F :"lowbattery",
;0x11 :"discreet",
;0x16 :"camerashutter",
;0x17 :"camerashutter1",
;0x18 :"camerashutter2",
;0x19 :"camerashutter3",
;0x1A :"cameraburst",
;0x1B :"cameratimer",
;0x1C :"timer",
;0x1D :"video"
;W580 R8BE001
;Short vibrations when playing a video in Video Player or File Manager
;© K790alex
;(p) Pakoko
44F506A2: 0022 8047
44F50710: D107F544 31BFCF45
45CFBF30: 00000000000000000000000000000000 0B480022FFB5002081B00090A2B06846
45CFBF40: 00000000000000000000000000000000 06498847FF21F53132220B1C0668FF24
45CFBF50: 00000000000000000000000000000000 69343659B04723B0FFBDFFFFD51C2E45
45CFBF60: 00000000 D107F544
;W580 R8BE001
;Short vibration when entering message "Sony Ericsson ROCKS!"
;In ServiceMenu -> ModelInfo -> Press 2,4,6,8
;Add the posibility to Change message for any text in code "ASCII" and No limits for text
;In example the text is "W580 Walkman"
; (R) D-man
; (c) k790alex
; (p) Pakoko
;v.1.1
4501B088: 1522 8047
4501B0A8: D8BEB145 B1BFCF45
45CFBFB0: 00000000000000000000000000000000 0A48F022FFB5002081B00090A2B06846
45CFBFC0: 00000000000000000000000000000000 07498847FF21F53132220B1C0668FF24
45CFBFD0: 00000000000000000000000000000000 69343659B04723B0FFBDFFFFE4BFCF45
45CFBFE0: 00000000 D51C2E45
;Your text here
45CFBFE4: 00000000000000000000000000000000 573538302057616C6B6D616E00000000
45CFBFF4: 00000000000000000000000000000000 00000000000000000000000000000000
;W580 R8BE001
;Добавить возможность включать автоматически
й режим USB при подключении кабеля
;Автоматически
й режим отключается выбором пункта "Нет"
;Установка режима осуществляетс
я в "Параметры" -> "Связь" -> "USB" -> "Подключение USB"
;Или в стандартном меню выбора режима -> "Функции" -> "Настройки"
;Add the ability to automatically choose the first USB mode when connecting the cable
;The automatic mode is disabled by selecting "No"
;Setting of the mode is in "Settings" -> "Connectivity" -> "USB" -> "USB connection"
;Or in the standard menu of choice of the mode -> "More" -> "Options"
;v1.0 fix:
;Исправлен баг с перезагрузкой
;Fixed bug with reboot
;(!) Heap shift - 201A4100...201A4120
;(С) MaPkiZzz aka Vital
;(p) Hy6uK
45215D92: 0121 0121; Стиль меню/Style menu
45215DF2: 0521 0921; Стиль GUI/Style GUI
45214F8C: 05D0 C046
45214F6A: 0021052000F025FE C046C04600F014F8
45214F9A: 0A4801220190052101A832F146FA011C 0A490847C046C046C046C046C046C046
45214FAA: 201C70F1DAF80121 C046C046C046C046
45214FC4: 1E1D0000 89C0CF45
45215C3A: 054998F0C2FA 05498847C046
45215C50: 9055B745 31C0CF45
45215C2E: 07D1 C046
45215D86: 2AD0 C046
45215DC2: 984A2549206A6BF19AFC C046C046C04600F009F8
45215DDE: 1B4831F1CAF91A49019001A841601949 1B4A0021206A6BF18CFC194A0021206A
45215DEE: 03228160 6BF1C3FC
45215DF4: 31F11EFB071C0021201C5EF14BFF2062 206A4FF177F8E7E7C046C046C046C046
45215E04: 09214FF16FF8381C31F1AAFB011C206A C046C046C046C046C046C046C046C046
45215E14: 00225FF18DF97E4A7C49206A6BF16EFC C046C046C046C046C046C046C046C046
45215E24: 206A321C291C6BF169FC206A4FF132F8 C046C046C046C046C046C046C046C046
45215E34: 381C31F1E1FB C046C046C046
45215E4C: 70EB000020000078 89C0CF45AD200000
45CFC030: 00000000000000000000000000000000 F0B5134D764E04003078002818D100F0
45CFC040: 00000000000000000000000000000000 43F8B71E3878002803D12900200000F0
45CFC050: 00000000000000000000000000000000 15F93878012803D10A49200000F00EF9
45CFC060: 00000000000000000000000000000000 387802280AD0032806D100F00BF903E0
45CFC070: 00000000000000000000000000000000 2900200000F002F900203070F0BDC046
45CFC080: 00000000000000000000000000000000 9055B7450C56B7450D4810B50D4C00F0
45CFC090: 00000000000000000000000000000000 FDF800280DD10021704B0020C04303B4
45CFC0A0: 00000000000000000000000000000000 0022200000F0F6F8200000F035F802B0
45CFC0B0: 00000000000000000000000000000000 03E00021200000F0F5F8002010BDC046
45CFC0C0: 00000000000000000000000000000000 45C2CF4504411A2030B5124D0400012C
45CFC0D0: 00000000000000000000000000000000 05D1002229002C31280000F0E7F80020
45CFC0E0: 00000000000000000000000000000000 01B4FF238133FF22093229002C312800
45CFC0F0: 00000000000000000000000000000000 00F0E0F83949050001B0002C03D10222
45CFC100: 00000000000000000000000000000000 00F0E0F802E0022200F0E0F8280000F0
45CFC110: 00000000000000000000000000000000 E1F830BD64C3CF453FB5050000F0DEF8
45CFC120: 00000000000000000000000000000000 1E490400AC61684610231B1FCA58C250
45CFC130: 00000000000000000000000000000000 FBD10020FFF7C8FF1949200000F0D2F8
45CFC140: 00000000000000000000000000000000 04226946200000F0D1F8244801782000
45CFC150: 00000000000000000000000000000000 00F0D0F8134A3F218901200000F0CEF8
45CFC160: 00000000000000000000000000000000 114A1249200000F0C9F8114A00212000
45CFC170: 00000000000000000000000000000000 00F0C4F80F4A0021200000F0C3F80E4A
45CFC180: 00000000000000000000000000000000 0121200000F0BAF80C4A0121200000F0
45CFC190: 00000000000000000000000000000000 B9F8200000F0BAF83FBDC046B0C3CF45
45CFC1A0: 00000000000000000000000000000000 4F0E0000E1C1CF45C1C1CF45C20F0000
45CFC1B0: 00000000000000000000000000000000 15C2CF45E9030000E9C1CF451F1D0000
45CFC1C0: 00000000000000000000000000000000 10B50400A06900F0A5F8044908700120
45CFC1D0: 00000000000000000000000000000000 FFF77AFF200000F0A1F810BD00411A20
45CFC1E0: 00000000000000000000000000000000 00B500F09BF800BD084800B500F04EF8
45CFC1F0: 00000000000000000000000000000000 002807D10648012101700021052000F0
45CFC200: 00000000000000000000000000000000 91F800BD002100F04DF800BD61C2CF45
45CFC210: 00000000000000000000000000000000 02411A20084A094810B5002100F086F8
45CFC220: 00000000000000000000000000000000 04000021002003B40123020004482100
45CFC230: 00000000000000000000000000000000 00F080F81CBDC046FFFF0000C0C3CF45
45CFC240: 00000000000000000000000000000000 FFFFFF6F054900B50068406800F07AF8
45CFC250: 00000000000000000000000000000000 002801D1012000BD002000BD4CC3CF45
45CFC260: 00000000000000000000000000000000 054900B50068406800F06CF8002801D1
45CFC270: 00000000000000000000000000000000 012000BD002000BDF4C3CF45004B1847
45CFC280: 00000000000000000000000000000000 C5E22A45004B1847CD24FC44004B1847
45CFC290: 00000000000000000000000000000000 99DC2A4508B4024B9C4608BC6047C046
45CFC2A0: 00000000000000000000000000000000 49E42A45004B18472DE72A45004B1847
45CFC2B0: 00000000000000000000000000000000 2585E84408B4024B9C4608BC6047C046
45CFC2C0: 00000000000000000000000000000000 4D7AE844004B1847A192E844004B1847
45CFC2D0: 00000000000000000000000000000000 6D94E844004B18471990E844004B1847
45CFC2E0: 00000000000000000000000000000000 FD033245004B1847C9533645004B1847
45CFC2F0: 00000000000000000000000000000000 15063245004B1847E1053245004B1847
45CFC300: 00000000000000000000000000000000 01173845004B184779173845004B1847
45CFC310: 00000000000000000000000000000000 994E3645004B1847F1053245004B1847
45CFC320: 00000000000000000000000000000000 65EA2A45004B1847BD5B2145004B1847
45CFC330: 00000000000000000000000000000000 3574344508B4024B9C4608BC6047C046
45CFC340: 00000000000000000000000000000000 7D982B45004B1847257455444D617373
45CFC350: 00000000000000000000000000000000 53746F7261676553657474696E677342
45CFC360: 00000000000000000000000000000000 6F6F6B002F007400700061002F007300
45CFC370: 00000000000000000000000000000000 79007300740065006D002F0073006500
45CFC380: 00000000000000000000000000000000 7400740069006E00670073002F000000
45CFC390: 00000000000000000000000000000000 4D00610073007300530074006F007200
45CFC3A0: 00000000000000000000000000000000 6100670065002E00620069006E000000
45CFC3B0: 00000000000000000000000000000000 AA0D00002B1D00003E1D0000530E0000
45CFC3C0: 00000000000000000000000000000000 28004300290020004D00610050006B00
45CFC3D0: 00000000000000000000000000000000 69005A007A007A00200061002E006B00
45CFC3E0: 00000000000000000000000000000000 2E006100200056006900740061006C00
45CFC3F0: 00000000000000000000000000000000 000000004D61737353746F7261676546
45CFC400: 000000000000000000000000 756E6374696F6E426F6F6B00
;W580 R8BE001
;Move characters and smiles in table
;Smiles 1 position (Add four smiles)
;V.1.2
;(C) Pakoko
45BB443C: 2E003F0021002C003A003B002D00 D3F2DEF2D7F2DAF2DCF2DBF2CFF2
45BB444A: 270022002F0028002900D3F2DEF2 D8F2D2F2D9F2D1F2D5F2DDF2D6F2
45BB4458: D7F2DAF2DCF2DBF2CFF2D8F2D2F2 D4F2D0F22E003F0021002C003A00
45BB4466: D9F2D1F2D5F22B002A003D005C00 3B002D0022002F00280029002B00
45BB4474: 4000260025003C003E0023000A00 2A003D005C00400025003C003E00
45BB4482: 29205F00A3002400AC20A200A500 23000A0029205F00A3002400AC20
45BB4490: A700C203A900AE00A400BF00A100 A200A500A700A900AE00A400BF00
45BB449E: 7C00 A100
;W580 R8BE001
;Vibration when entering in Equalizer on MediaPlayer
;© AlexMasteR a.k.a K790alex
;(p) Pakoko
+44140000
df4b3e: 0022 8047
df4c34: 194DF344 D1C2CF45
1bbc2d0: 00000000000000000000000000000000 09480022FFB5002081B00090A2B06846
1bbc2e0: 00000000000000000000000000000000 06498847064932220B1C0668FF246934
1bbc2f0: 00000000000000000000000000000000 3659B04723B0FFBD194DF344D51C2E45
1bbc300: 00000000 EE020000;Time
not found: Poprawiłem nazwę tematu i przykleiłem. Dodałem spis patchy, żeby łatwiej było je znaleźć (14.12.2013). Poprawki (11.02.2014) :) Porzeszyłem spis patchy (19.03.2014).
Edited by not found, 19 March 2014 - 16:14.
W995 forever
Posted 11 November 2013 - 16:15
;W580 SW-R8BE001
;Remove messages "Quick charging" and "Fully charged"
;© IronMaster
;(p)BloodyMessage
+44140000
117E563: 0022 1BE0
;W580 SW-R8BE001
;Turn off color diods (no bug!)
;(C) UltraShot
4529BF60: 02F02AFB C046C046
4529BF82: 02F06BF9 C046C046
4529BF98: 02F0E0F9 C046C046
4529BFC2: 02F089F9 C046C046
4529BFD8: 02F0ECF9 C046C046
4529BFEC: 02F012FA C046C046
4529C000: 02F034FA C046C046
4529C014: 02F056FA C046C046
4529C02C: 02F030FB C046C046
4529C040: 02F09EFB C046C046
;W580 R8BE001
;ifs/settings/acoustic -> card/other/drv/snd
;ifs/settings/camera -> card/other/drv/cam
;(c) Belk
;(p) faridbahal
+44140000
194E002: 2F006900660073002F00730065007400740069006E00670073 002F00630061006D00650072006100 2F0063006100720064002F006F0074006800650072002F0064 00720076002F00630061006D000000
194DF96: 2F006900660073002F00730065007400740069006E00670073 002F00610063006F0075007300740069006300 2F0063006100720064002F006F0074006800650072002F0064 00720076002F0073006E006400000000000000
19C6C00: 2F006900660073002F00730065007400740069006E00670073 002F00610063006F0075007300740069006300 2F0063006100720064002F006F0074006800650072002F0064 00720076002F0073006E006400000000000000
;W580-R8BE001
;Heap shift! More stability for patches!
;(c) den_po
;(p)-=Tanusha_SE=-
;v.64k
;info 4 patchmakers: 0x201A4064...0x201B4063
;this info is firmware version dependent
+44140000
fb7b4: 68480A216860 684988470A21
fb958: 00501400 214DBF45
1ab4d20: 00000000000000000000000000000000 0CB50649002301229203036004300439
1ab4d30: 00000000000000000000000000000000 013A002AF9D1286069600CBD00501400
;W580 SW-R8BE001
;Office player and radio through the headset
;One pressing - next song / station
;Two or more applications - to turn off the player / radio
;If not included radio or player, includes pressing that button set to music
;Need to include voice dialing
;(!) HeapShift (201A4064 - 201A4067)
;v. 4
;(c) IronMaster
;(p) -= Tanusha_SE =-
+44140000
19d0af4: 41E1FF44 C14DBF45
1ab4dc0: 00000000000000000000000000000000 FCB5254F3E78002E08D101203870FF20
1ab4dd0: 00000000000000000000000000000000 913004A1013100F02DF8FCBD01363E70
1ab4de0: 00000000000000000000000000000000 FCBDC046FCB51C4F3E78002139701748
1ab4df0: 00000000000000000000000000000000 00F01EF8002807D1154800F019F80028
1ab4e00: 00000000000000000000000000000000 0BD1144FB847FCBD012E02D000F00EF8
1ab4e10: 00000000000000000000000000000000 FCBD12480C498847FCBD012E02D000F0
1ab4e20: 00000000000000000000000000000000 05F8FCBD0021064A9047FCBD03490847
1ab4e30: 00000000000000000000000000000000 04490847004B184705B42A4565EA2A45
1ab4e40: 00000000000000000000000000000000 F18E0F4509CB2A45D1CE2A45554EF344
1ab4e50: 00000000000000000000000000000000 09AD0F452D63214564401A2057080000
;W580_SW-R8BE001
;Disables STARTUP_IMAGE, SHUTDOWN_IMAGE and STARTUP_SOUND.mid
;version 2
;(c) afghanjohnny
;(p)-=Tanusha_SE=-
45BAA8C6: 53 54
45BAA8EC: 53 54
45BAA914: 53 54
45BAA93A: 53 54
;W580 SW-R8BE001
;Disable setup wizard when changing SIM-card
;© den_po
;(p) -=Tanusha_SE=-
452C2B34: 02D1 09E0
;W580 SW-R8BE001
;Remove java security restrictions
;(с) the_laser
;(p) -=Tanusha_SE=-
4527A288: 01D0 01E0
4527A28E: 00 01
;W580 R8BE001
;Possibility to store more SMS (was 1000)
;Remove the ; on the one you wish to have
;(c) demion
;(p) faridbahal
;4512E8AE: FA229200 7d221201; 2000 SMS
;4512E8AE: FA229200 FA221201; 4000 SMS
4512E8AE: FA229200 9D229201; 10000 SMS
;W580 R8BE001
;Phone without SIM card
;Works: Camera, Player, Radio, Alarms, Timer, Stopwatch, Calculator
;Not running: Java, Browser, Bluetooth, Calendar, Tasks, Activity menu...
;(c) Mobilefree
;(p) faridbahal
44DC61CA: 0C1C 6EE0
;W580 R8BE001
;Radio without headsets
;(c) SiNgle
;(p) Dmi3y
+44140000
FBAC28: 01D1 01E0
;W580 R8BE001
;Walkman Key as Play/Pause button
;(c) Sic
;(p) MILAD
+44140000
116de8a: 47 42
;W580 SW-R8BE001
;Setting the menu in landscape mode
;(c) Ploik
;(p) albertnet3
452dc516: 0C1C0021201C 624C2047C046
452dc6a0: 3DEC0000 B1C62D45
452dc6b0: 04D0012D05D0022D2BD02DE0 0C1C0121201CD2F767FA17E0
452dc6ec: 22D1164D1248 0021201C14E7
;W580 SW-R8BE001
;Recording with .mp3 file format
;It works only with voice recording
;© ValX
;(p) albertnet3
45AEEE7E: 61006D0072 6D00700033
;W580 SW-R8BE001
;Switching to more than 2 input languages with a key #
;Window "Input Language" does not appear
; © 2007KrasH
;(p) albertnet3
452F1EE6: 03 FF
;W580 R8BE001
;Add information about mp3
;Add items Bitrate, Samplerate and Channel mode
;(C) Joker XT
;(p) albertnet3
44ebb782: 86B0 88B0
44ebb7c8: 06B0 08B0
44ebb794: 7060 F060
44ebb7b2: 05A9 07A9
44ebb79c: F060 7061
44ebb7b0: 3061 B061
44ebb7ba: 0622 0822
44ebb796: 0F48B060 0F498847
44ebb7d4: AE040000 393ECC45
45cc3e38: 00000000000000000000000000000000 FFB587B0201C371C7D4EB047031C7A4E
45cc3e48: 00000000000000000000000000000000 B047011C181C794EB047051C002001B4
45cc3e58: 00000000000000000000000000000000 FF2381330122281C764EB04701B00090
45cc3e68: 00000000000000000000000000000000 0A2202A90098744EB047009902A800F0
45cc3e78: 00000000000000000000000000000000 92F8042201A900986F4EB04700986F4E
45cc3e88: 00000000000000000000000000000000 B04701A800F02DF888B000F05BF80190
45cc3e98: 00000000000000000000000000000000 7EA000F057F800907FA000F053F80390
45cc3ea8: 00000000000000000000000000000000 09A800F069F800F04DF8049009A800F0
45cc3eb8: 00000000000000000000000000000000 53F800F047F8079064A000F043F80690
45cc3ec8: 00000000000000000000000000000000 574802900590082205216846554EB047
45cc3ed8: 00000000000000000000000000000000 08B0B8605248786007B0FFBC4D483061
45cc3ee8: 00000000000000000000000000000000 00BD00B581780909002900D16EA00129
45cc3ef8: 00000000000000000000000000000000 00D16FA0022900D16FA0032900D170A0
45cc3f08: 00000000000000000000000000000000 042900D170A0052900D171A0062900D1
45cc3f18: 00000000000000000000000000000000 71A0072900D172A0082900D172A00929
45cc3f28: 00000000000000000000000000000000 00D173A00A2900D173A00B2900D174A0
45cc3f38: 00000000000000000000000000000000 0C2900D174A00D2900D175A00E2900D1
45cc3f48: 00000000000000000000000000000000 75A000BD00B5031C3D4EB047021C0121
45cc3f58: 00000000000000000000000000000000 181C344EB04700BDFEB5C07880090028
45cc3f68: 00000000000000000000000000000000 00D13EA0012800D13EA0022800D141A0
45cc3f78: 00000000000000000000000000000000 032800D143A0FEBDFEB580780C221040
45cc3f88: 00000000000000000000000000000000 8008002800D166A0012800D166A00228
45cc3f98: 00000000000000000000000000000000 00D167A0FEBDFEB50178492921D14178
45cc3fa8: 00000000000000000000000000000000 44291ED1817833291BD1C178032912D1
45cc3fb8: 00000000000000000000000000000000 81794905C27992031143027AD2011143
45cc3fc8: 00000000000000000000000000000000 427A11431448814200D1144901220098
45cc3fd8: 00000000000000000000000000000000 1C4EB047FEBD417A01220098194EB047
45cc3fe8: 00000000000000000000000000000000 07E0071C002200210098164EB047FF2F
45cc3ff8: 00000000000000000000000000000000 0FD081B00122694601980F4EB0476946
45cc4008: 00000000000000000000000000000000 0878FF28F6D101220F4901980D4EB047
45cc4018: 00000000000000000000000000000000 01B0FEBD71040000F607000097090000
45cc4028: 00000000000000000000000000000000 0A0000783574344525F7EC44D9F7EC44
45cc4038: 00000000000000000000000000000000 AD08EB444D7AE844A192E8441990E844
45cc4048: 00000000000000000000000000000000 817455441596E844FFFFFFFF4368616E
45cc4058: 00000000000000000000000000000000 6E656C206D6F64653A2000FF53746572
45cc4068: 00000000000000000000000000000000 656F00FF4A6F696E742D73746572656F
45cc4078: 00000000000000000000000000000000 00FFFFFF4475616C204368616E6E656C
45cc4088: 00000000000000000000000000000000 00FFFFFF4D6F6E6F00FFFFFF42697472
45cc4098: 00000000000000000000000000000000 6174653A2000FFFF53616D706C657261
45cc40a8: 00000000000000000000000000000000 74653A2000FFFFFF306B62707300FFFF
45cc40b8: 00000000000000000000000000000000 33326B62707300FF34306B62707300FF
45cc40c8: 00000000000000000000000000000000 34386B62707300FF35366B62707300FF
45cc40d8: 00000000000000000000000000000000 36346B62707300FF38306B62707300FF
45cc40e8: 00000000000000000000000000000000 39366B62707300FF3131326B62707300
45cc40f8: 00000000000000000000000000000000 3132386B627073003136306B62707300
45cc4108: 00000000000000000000000000000000 3139326B627073003232346B62707300
45cc4118: 00000000000000000000000000000000 3235366B627073003332306B62707300
45cc4128: 00000000000000000000000000000000 3434313030487A003438303030487A00
45cc4138: 0000000000000000 3332303030487A00
;W580 SW-R8BE001
;Phone password when entering QuickAccess Menu
;(!) It's needed Privacy v.3 patch
;© Laura_P
;(p) Juanchy - JYM
;v.1 fix
45BB148C: EC14BB45 B431C545
45C531A0: 00000000000000000000000000000000 F0B500F021F8F0BDF0B5081C09A100F0
45C531B0: 00000000000000000000000000000000 17F8F0BD07000000A131C5451F000000
45C531C0: 00000000000000000000000000000000 A931C54508000000A5C52D4500000000
45C531D0: 00000000000000000000000000000000 000000003014BB4500000000EC14BB45
45C531E0: 00000000000000000000000000000000 004D2847C5E12A45004B1847CB5FCF45
;W580 SW-R8BE001
;Fully operational phone without a SIM-card
;Everything works except the functions that require cellular communication
;Fixed the "Protection of the phone" when you turn on without a SIM-card
;(!) For working "Protection of the phone" need to patch:
;"Fixing Password Authentication phone if there is no SIM-card "
;v.1.3
;© KrasH
;(p) albertnet3
45babaa4: 65132C45 4110DB45
45db1040: 00000000000000000000000000000000 10B587B00C1C002269460A704A6001A8
45db1050: 00000000000000000000000000000000 00F022F80198002811D1002168460170
45db1060: 00000000000000000000000000000000 00F01EF86846007800280CD0201C00F0
45db1070: 00000000000000000000000000000000 15F8084B0222042100F018F806E0211C
45db1080: 00000000000000000000000000000000 00F010F802E0211C00F00EF8012007B0
45db1090: 00000000000000000000000000000000 10BDFFFFCE150000074B1847074B1847
45db10a0: 00000000000000000000000000000000 074B1847074B1847074B184708B4074B
45db10b0: 00000000000000000000000000000000 9C4608BC6047FFFF1972DC4425EB2A45
45db10c0: 00000000000000000000000000000000 9D2D634465132C4575132C45B93FDC44
;W580 SW-R8BE001
;Fixing the phone password verification if there is no SIM-card
;© KrasH
;(p) albertnet3
446301ac: 09D0 09E0
;W580 SW-R8BE001
;Change the time of drawing in mediaplayer
;More fast in mediaplayer
;©Fernandodks
44F32750: 8A02 D007
;W580 SW-R8BE001
;Add-On "BLEplayer.elf" ©jUlIoNaRu
;Enter to walkman and press More->BLEplayer to start the elf
;The path for elf file is: "/tpa/user/other/ZBin/BLEplayer.elf"
;(!) Is needed to edit the label "2311" with "LNG Editor" for your like
;©K790alex
44F36D00: 002805D0 C0462847
44F36ECC: CD040000 01482944
44294800: 00000000000000000000000000000000 0A4A3B21E0690B4B98470C4A3B21E069
44294810: 00000000000000000000000000000000 094B9847064D002804D0014B1847C046
44294820: 00000000000000000000000000000000 056DF344004B1847116DF34440482944
44294830: 00000000000000000000000000000000 CD040000D948F3440D49F34411230000
44294840: 00000000000000000000000000000000 00402DE9741090E50030A0E3082091E5
44294850: 00000000000000000000000000000000 041091E504008FE20D0100EF0080BDE8
44294860: 00000000000000000000000000000000 2F007400700061002F00750073006500
44294870: 00000000000000000000000000000000 72002F006F0074006800650072002F00
44294880: 00000000000000000000000000000000 5A00420069006E002F0042004C004500
44294890: 00000000000000000000000000000000 70006C0061007900650072002E006500
442948A0: 000000000000 6C0066000000
;W580 SW-R8BE001
;Add to QuickAccess menu items: "To Standby" and "Close all running Java"
;© 2007KrasH
;(p) albertnet3
452dc632: 042D1DD3F8F795F9C01C 01480047FFFF993CCC45
452dc718: 042D0BD3F8F722F9 00480047E53CCC45
452dc54a: 011D C11D
45cc3c98: 00000000000000000000000000000000 042D0DD0052D13D0062D19D0072D1BD3
45cc3ca8: 00000000000000000000000000000000 00F056F8801DA84216DBED1E3E480047
45cc3cb8: 00000000000000000000000000000000 414A002144A000F04DF8061C3F4F0BE0
45cc3cc8: 00000000000000000000000000000000 3D4A002146A000F045F8061C3C4F03E0
45cc3cd8: 00000000000000000000000000000000 0121201C00F040F834480047042D0BD0
45cc3ce8: 00000000000000000000000000000000 052D31D0072D31D300F032F8801DA842
45cc3cf8: 00000000000000000000000000000000 2CDBED1E2E48004700F030F8002100F0
45cc3d08: 00000000000000000000000000000000 2FF823E0FFB500F02DF8071C0026301C
45cc3d18: 00000000000000000000000000000000 00F02AF8051C0021006800F027F8041C
45cc3d28: 00000000000000000000000000000000 3CA10068406800F023F8002803D0761C
45cc3d38: 00000000000000000000000000000000 BE42ECDB07E0201C00F01CF8011C2148
45cc3d48: 00000000000000000000000000000000 00F01AF8F3E7FFBDFFF7DCFF19480047
45cc3d58: 00000000000000000000000000000000 0A4B18470A4B18470A4B18470A4B1847
45cc3d68: 00000000000000000000000000000000 0A4B18470A4B18470A4B18470A4B1847
45cc3d78: 00000000000000000000000000000000 0A4B18470A4B18470A4B184765492D45
45cc3d88: 00000000000000000000000000000000 3574344559F03145351A2C45F5E62A45
45cc3d98: 00000000000000000000000000000000 09CC2A4515CC2A45A15B1B4525745544
45cc3da8: 00000000000000000000000000000000 25EB2A4529CF2A4541C62D4573C62D45
45cc3db8: 00000000000000000000000000000000 27C72D4535C72D45FFFF000049EA0000
45cc3dc8: 00000000000000000000000000000000 38EC00004A08000054006F0020005300
45cc3dd8: 00000000000000000000000000000000 740061006E006400620079000000FFFF
45cc3de8: 00000000000000000000000000000000 530068007500740064006F0077006E00
45cc3df8: 00000000000000000000000000000000 200061006C006C002000520075006E00
45cc3e08: 00000000000000000000000000000000 6E006500640020004A00610076006100
45cc3e18: 00000000000000000000000000000000 0000FFFF435549446973706C61796162
45cc3e28: 00000000000000 6C65426F6F6B00
;W580 SW-R8BE001
;Add free heap in shutdown menu
;(c) Ploik
;(p) albertnet3
452dc6ea: 0028 23E0; Remove window \"Silent mode on\" (when you turn it on from the shutdown
menu)
452dc528: 0221 0421; GUI Style
452dc52e: A069012188F03BFF 83480047C046C046
452dc73c: DC050000 093CCC45
45cc3c08: 00000000000000000000000000000000 00F00AF8011CA06900F025F8A0690321
45cc3c18: 00000000000000000000000000000000 00F023F8174800470EB50622062116A0
45cc3c28: 00000000000000000000000000000000 00F017F8009000F010F8800A00F00FF8
45cc3c38: 00000000000000000000000000000000 01900322062112A000F00BF802900322
45cc3c48: 00000000000000000000000000000000 0521684600F005F80EBD064B1847064B
45cc3c58: 00000000000000000000000000000000 1847034B1847054B1847054B1847FFFF
45cc3c68: 00000000000000000000000000000000 3574344565DDF74481713445C9533645
45cc3c78: 00000000000000000000000000000000 AD53364537C52D45486561703A200000
45cc3c88: 00000000 204B4200
;W580 SW-R8BE001
;More lines in SMS Editor
;(c) jamesbond22
;(p) albertnet3
4535C2E4: 02F010FD C046C046
;W580 SW-R8BE001
;Delete/Change items (label) in "Phone status"
;v.1
;(c) Mobilefree.ru
;(p) MaxxxS
452C2D2A: A9A8 63E0 ;Profile
452C2DA6: 1AD1 1AE0 ;Model
452C2E3E: 2CD0 2CE0 ;My mobile
452C31D0: F4040000 F6040000 ; "Memory Stick Card:" -> "Memory Stick"
;W580 SW-R8BE001
;Setting the display brightness in voice conversations
;After call, the display brightness returns to previous value
;v.1.5
;(c) 2007KrasH
;(p) M.R.2/mm
45aa416c: 493EDB44 B13ACC45; For outgoing calls
44db68b4: DD6BDB44 BF3ACC45; For incoming calls
45babe50: 79372C45 CB3ACC45
45cc3ab0: 00000000000000000000000000000000 F1B502B400F01AF802BC094B184711B5
45cc3ac0: 00000000000000000000000000000000 00F014F801BC074B184701B500F01EF8
45cc3ad0: 00000000000000000000000000000000 011C002000F01CF801BC03490847FFFF
45cc3ae0: 00000000000000000000000000000000 4B3EDB44BF6DDB447B372C4500B50BA1
45cc3af0: 00000000000000000000000000000000 0978002000F001F800BD10B5041C6529
45cc3b00: 00000000000000000000000000000000 00D36421004A10477F1C3945014B1847
45cc3b10: 000000000000000000000000 014B184731432D45B9613645
45cc3b1c: 00 46; Brightness percent 0-100% in hex value
;W580 SW-R8BE001
;Keylock and sleepmode at the end of the voice conversations
;(c) jamesbond22
;(r) Ploik
;(p)albertnet3
44da4108: 1141DA44 01632944
44296300: 00000000000000000000000000000000 00B500F00AF800F001F800BD00B50448
44296310: 00000000000000000000000000000000 00F001F800BD034B1847034B1847FFFF
44296320: 000000000000000000000000 B3070000D1CE2A451141DA44
;W580 SW-R8BE001
;Reversed colors in sleepmode
;(c) jamesbond22
;(p) Marvin
4539318E: FF210906 0021C943
45393196: 0021C943 FF210906
;W580 SW-R8BE001
;Vibra when entering Quick Acces Menu On/Off
;(c) AlexMasteR a.k.a k790alex
;Idea by Fernandoks
452DC560: A069 8847
452DC594: BDC52D45 A1806345
456380A0: 00000000000000000000000000000000 0949A069FFB5002081B00090A2B06846
456380B0: 00000000000000000000000000000000 06498847064932220B1C0668FF246934
456380C0: 00000000000000000000000000000000 3659B04723B0FFBDBDC52D45D51C2E45
456380D0: 00000000 EE020000 ;time
;W580 SW-R8BE001
;Set display brightness according to time and battery level v1.1
;(!) To start the patch you need to go: menu>settings>display>brightness and you must change brightness to different level !
;From 8: 00 to 11: 59 = 30%
;From 12: 00 to 19: 59 = 60%
;From 20: 00 to 7: 59 = 10%
;When battery level is lower than 10%, brightness will be reduced to 10%
;(!) To use with "Advanced range of brightness adjustment"
;(!) Heapshift (201A5324-201A5337)
;© mc_kibel
;(p)albertnet3
+44140000
119e750: 65E72D45 89F9DF45
1cbf8f0: 00000000000000000000000000000000 03B56946002000F05FF8024968460079
1cbf900: 00000000000000000000000000000000 08600CBD30531A2000B58DB069460120
1cbf910: 00000000000000000000000000000000 00F056F8034968462030007808600DB0
1cbf920: 00000000000000000000000000000000 00BDC04634531A2000B5FFF7E1FFFFF7
1cbf930: 00000000000000000000000000000000 EBFF0F490A208A680B2A12D34A68002A
1cbf940: 00000000000000000000000000000000 01D4082A0DDB082A03DB0C2A01DA1E20
1cbf950: 00000000000000000000000000000000 07E00C2A03DB142A01DA3C2001E0142A
1cbf960: 00000000000000000000000000000000 00DB08600968002000F02EF800BDC046
1cbf970: 00000000000000000000000000000000 2C531A2000B5FFF7D7FF0E4A0C490B48
1cbf980: 00000000000000000000000000000000 002300F025F800BD10B5084C60680028
1cbf990: 00000000000000000000000000000000 08D107480749002200F022F820806068
1cbf9a0: 00000000000000000000000000000000 401C606000F020F810BD000024531A20
1cbf9b0: 00000000000000000000000000000000 B80B000075F9DF45004B18473198D444
1cbf9c0: 00000000000000000000000000000000 004B1847895C9C44004B1847B9613645
1cbf9d0: 00000000000000000000000000000000 08B4024B9C4608BC6047C04639B42A45
1cbf9e0: 00000000000000000000000000000000 004B184705B42A4508B4024B9C4608BC
1cbf9f0: 00000000000000000000000000000000 6047C04665E72D451400000024531A20
1cbfa00: 000000000000 24531A200000
;W580 SW-R8BE001
;Ability to turn On / Off file transfer
;Settings - Connection - Bluetooth - My phone\'s name
;Options - Cancel or activate the file transfer
;(!) conflicts with "Password for file transfer / viewing videos in the file manager / video player" patch
;© ZEN
;® Ploik
;(p)albertnet3
+44140000
c3e9e2: 0F4A A847
c3ea30: AC0F0000 49FBDF45
198b53c: C154EB44 11FBDF45
1cbfb10: 00000000000000000000000000000000 FFB500F00EF8012805D000F001F8FFBD
1cbfb20: 00000000000000000000000000000000 F0B5234F384700F001F8FFBDF0B5214F
1cbfb30: 00000000000000000000000000000000 384706B52248002222A100F05FF801D4
1cbfb40: 00000000000000000000000000000000 012000E0002006BDFFF7F3FF002806D0
1cbfb50: 00000000000000000000000000000000 204A0021A06900F049F8CA2205E01E4A
1cbfb60: 00000000000000000000000000000000 0021A06900F042F81C4A0021A06900F0
1cbfb70: 00000000000000000000000000000000 41F801220021A06900F050F8194D1A4A
1cbfb80: 00000000000000000000000000000000 174B1847FFB50E480EA1002200F042F8
1cbfb90: 00000000000000000000000000000000 FFBDFFB5002001B409480AA10422FF23
1cbfba0: 00000000000000000000000000000000 813300F02FF800F031F801B0FFBDFFFF
1cbfbb0: 00000000000000000000000000000000 C354EB44A756EB44729631457F963145
1cbfbc0: 00000000000000000000000000000000 D8867145420074002E00620069006E00
1cbfbd0: 00000000000000000000000000000000 0000FFFF85FBDF4593FBDF4511230000
1cbfbe0: 00000000000000000000000000000000 E5E9D744AC0F000035EAD744004B1847
1cbfbf0: 00000000000000000000000000000000 01173845004B184779173845004B1847
1cbfc00: 00000000000000000000000000000000 E183E844004D28474D7AE844004D2847
1cbfc10: 00000000000000000000000000000000 1990E844004D28472585E844004B1847
1cbfc20: 00000000 C9173845
;W580 SW-R8BE001
;Change On/Off menu style
;Added FlightMode and Restart elements
;Added displaying FlightMode icon
;Added Camera, MediaPlayer and FMRadio
;v.1 fix
;(!) Remove every patch connected to the On/Off menu first
;© michlantecuhtli
;(e)AlexMasteR
;(p)albertnet3
;Mod V1.5
+44140000
118205c: 03D1 C046
119c546: F8F70DFA011D C046C0460921
119c538: 0021 0221
119c5e4: 051C574800680190 004D2847014E2944
119c6a6: 041C081C41F0D7FE051C 014C2047C046154F2944
154e00: 00000000000000000000000000000000 051C904800680190002D10D0012D11D0
154e10: 00000000000000000000000000000000 022D12D0032D1AD0042D29D0052D2AD0
154e20: 00000000000000000000000000000000 062D2BD0072D2CD0082D2DD02EE0734E
154e30: 00000000000000000000000000000000 734F2BE0734E744F28E000F0AFF80028
154e40: 00000000000000000000000000000000 02D0744E744F21E0704E714F1EE00198
154e50: 00000000000000000000000000000000 6A460121C94300F09CF8002805D16846
154e60: 00000000000000000000000000000000 0078012801D1614E00E01826604F0DE0
154e70: 00000000000000000000000000000000 604E614F0AE0694E6A4F07E06A4E6B4F
154e80: 00000000000000000000000000000000 04E06B4E6B4F01E06B4E6C4F002D10D0
154e90: 00000000000000000000000000000000 012D12D0022D14D0032D1ED0042D20D0
154ea0: 00000000000000000000000000000000 052D22D0062D22D0072D24D0082D26D0
154eb0: 00000000000000000000000000000000 2EE08AA000210D2223E08FA000210F22
154ec0: 00000000000000000000000000000000 1FE000F06BF8002803D07AA000211222
154ed0: 00000000000000000000000000000000 17E06FA00021112213E08FA000211222
154ee0: 00000000000000000000000000000000 0FE097A000210D220BE04D490DE09BA0
154ef0: 00000000000000000000000000000000 00210D2205E0A5A000210D2201E05049
154f00: 00000000000000000000000000000000 03E000F055F8011CFFE7201C00F04BF8
154f10: 00000000000000000000000000000000 4D4D2847041C081C00F04FF8051C002D
154f20: 00000000000000000000000000000000 10D0012D11D0022D11D0032D1BD0042D
154f30: 00000000000000000000000000000000 1BD0052D1CD0062D1ED0072D20D0082D
154f40: 00000000000000000000000000000000 22D024E000F048F821E04148004700F0
154f50: 00000000000000000000000000000000 25F8002801D0002000E0012000F032F8
154f60: 00000000000000000000000000000000 00F035F813E03B4800473B4800470EE0
154f70: 00000000000000000000000000000000 434800F036F80AE0424800F032F806E0
154f80: 00000000000000000000000000000000 414800F02EF802E0404800F02AF82F48
154f90: 00000000000000000000000000000000 004708B4314B9C4608BC604708B4304B
154fa0: 00000000000000000000000000000000 9C4608BC604708B42F4B9C4608BC6047
154fb0: 00000000000000000000000000000000 08B42E4B9C4608BC604708B42C4B9C46
154fc0: 00000000000000000000000000000000 08BC604708B42B4B9C4608BC604708B4
154fd0: 00000000000000000000000000000000 294B9C4608BC604708B4224B9C4608BC
154fe0: 00000000000000000000000000000000 604708B4254B9C4608BC604707190000
154ff0: 00000000000000000000000000000000 CDF20000100D00003DEC0000FA080000
155000: 00000000000000000000000000000000 93F30000D30E0000C6F4000001080000
155010: 00000000000000000000000000000000 2BEB0000AF020000BCE50000E50C0000
155020: 00000000000000000000000000000000 AF0E000046EE00005605000030EA0000
155030: 00000000000000000000000000000000 ED05000084EE00001D0800008EEE0000
155040: 00000000000000000000000000000000 4B0800006863B04573C62D4535C72D45
155050: 00000000000000000000000000000000 BDC62D45C3C62D4513C72D45D1542E45
155060: 00000000000000000000000000000000 D5402D45D5969644D5EF314535743445
155070: 00000000000000000000000000000000 5DE4314539022C45B1022C45816F3845
155080: 00000000000000000000000000000000 B498BC456485BC4534E0BC45E8B7BC45
155090: 00000000000000000000000000000000 45006E00610062006C00650020004600
1550a0: 00000000000000000000000000000000 6C0069006700680074004D006F006400
1550b0: 00000000000000000000000000000000 65000000440069007300610062006C00
1550c0: 00000000000000000000000000000000 6500200046006C006900670068007400
1550d0: 00000000000000000000000000000000 4D006F00640065000000FFFF52006500
1550e0: 00000000000000000000000000000000 73007400610072007400200070006800
1550f0: 00000000000000000000000000000000 6F006E00650000005300680075007400
155100: 00000000000000000000000000000000 64006F0077006E002000700068006F00
155110: 00000000000000000000000000000000 6E0065000000FFFF43006F006E007400
155120: 00000000000000000000000000000000 72006F006C002000530069006C006500
155130: 00000000000000000000000000000000 6E0074004D006F00640065000000FFFF
155140: 00000000000000000000000000000000 4C006F0063006B0020004B0065007900
155150: 00000000000000000000000000000000 62006F00610072006400000053006100
155160: 00000000000000000000000000000000 76006500200059006F00750072002000
155170: 00000000000000000000000000000000 420065007300740020004D006F006D00
155180: 00000000000000000000000000000000 65006E00740073000000FFFF50006C00
155190: 00000000000000000000000000000000 61007900200059006F00750072002000
1551a0: 000000000000000000000000 4D0075007300690063000000
;W580 SW-R8BE001
;Add option to set current track as a ringtone
;In Walkman press More->File->Set as ringtone
;© MaPkiZzz aka Vital
;(p)Albertnet3
+44140000
df6ad8: 002805D0 C0463847
df6cc0: A1050000 B1512944
1551b0: 00000000000000000000000000000000 124AFF21E069134B98470F4AFF21E069
1551c0: 00000000000000000000000000000000 114B9847E0691521FF22104B9847094F
1551d0: 00000000000000000000000000000000 0B4B984710B5416F05488B684A680068
1551e0: 00000000000000000000000000000000 0B4C0021A04710BD00000000E8512944
1551f0: 00000000000000000000000000000000 EC51294454200000B90E0000D5512944
155200: 00000000000000000000000000000000 DD6AF344D948F3440D49F3449949F344
155210: 00000000 C9522E45
;W580 SW-R8BE001
;Settings - Connection - Bluetooth - My phone's name
;Options - Cancel transfering or transfer objects
;v2 Now works with selected files
;© ZEN
;®Ploik->DB2020
;(p)albertnet3
+44140000
c3e9e2: 0F4A A847
c3ea30: AC0F0000 6F522944
198b53c: C154EB44 21522944
1995c88: 7D6CEC44 43522944
155220: 00000000000000000000000000000000 FFB500F019F8012805D000F001F8FFBD
155230: 00000000000000000000000000000000 F0B52B4F384700F001F8FFBDF0B5294F
155240: 00000000000000000000000000000000 3847FFB500F008F80128F4D000F001F8
155250: 00000000000000000000000000000000 FFBDF2B5214F384706B52548002225A1
155260: 00000000000000000000000000000000 00F064F801D4012000E0002006BDA069
155270: 00000000000000000000000000000000 FFF7F2FF002807D0A069224A002100F0
155280: 00000000000000000000000000000000 4DF8A069CA2206E0A0691F4A002100F0
155290: 00000000000000000000000000000000 45F8A0691D4A002100F044F8A0690122
1552a0: 00000000000000000000000000000000 002100F053F8A0691A4D1B4A184B1847
1552b0: 00000000000000000000000000000000 FFB50F480FA1002200F044F8FFBDFFB5
1552c0: 00000000000000000000000000000000 002001B40A480BA10422FF23813300F0
1552d0: 00000000000000000000000000000000 31F800F033F801B0FFBDFFFF7F6CEC44
1552e0: 00000000000000000000000000000000 C354EB44A756EB44BF1D2C45CB1D2C45
1552f0: 00000000000000000000000000000000 D8867145420074002E00620069006E00
155300: 00000000000000000000000000000000 0000FFFFB1522944BF52294411230000
155310: 00000000000000000000000000000000 E5E9D744AC0F000035EAD744004B1847
155320: 00000000000000000000000000000000 01173845004B184779173845004B1847
155330: 00000000000000000000000000000000 E183E844004D28474D7AE844004D2847
155340: 00000000000000000000000000000000 1990E844004D28472585E844004B1847
155350: 00000000 C9173845
;W580 SW-R8BE001
;Choose menu style
;Change The style from Main Menu
;(!) Conflict with the patch "More options in main menu" By yener90
;© ZEN
;DB2020 By Ploik
;(e) K790Alex
;(p)albertnet3
+44140000
1246276: 544A5B49201CFBF740FAB068 014B1847C046BD532944C046
124629e: 391C201C98F703F9717B201C 014B9847C04661532944C046
155360: 00000000000000000000000000000000 00F093F8012815D000F08AF8012813D0
155370: 00000000000000000000000000000000 00F081F8012811D000F078F801280FD0
155380: 00000000000000000000000000000000 00F06FF801280DD000F066F801280BD0
155390: 00000000000000000000000000000000 391C0AE0012108E0032106E0042104E0
1553a0: 00000000000000000000000000000000 072102E0082100E00921201C00F00CF9
1553b0: 00000000000000000000000000000000 717B201C004B9847AB6238457F4A8049
1553c0: 00000000000000000000000000000000 201C00F005F9674A0421201C00F000F9
1553d0: 00000000000000000000000000000000 6B4A0421201C00F0FFF8634A0521201C
1553e0: 00000000000000000000000000000000 00F0F6F8674A0521201C00F0F5F85F4A
1553f0: 00000000000000000000000000000000 0621201C00F0ECF8634A0621201C00F0
155400: 00000000000000000000000000000000 EBF85B4A0821201C00F0E2F85F4A0821
155410: 00000000000000000000000000000000 201C00F0E1F8574A0921201C00F0D8F8
155420: 00000000000000000000000000000000 5B4A0921201C00F0D7F8534A0A21201C
155430: 00000000000000000000000000000000 00F0CEF8574A0A21201C00F0CDF84F4A
155440: 00000000000000000000000000000000 0B21201C00F0C4F8534A0B21201C00F0
155450: 00000000000000000000000000000000 C3F8B068584B184706B55048002255A1
155460: 00000000000000000000000000000000 17E006B54D48002251A112E006B54B48
155470: 00000000000000000000000000000000 00224EA10DE006B5484800224AA108E0
155480: 00000000000000000000000000000000 06B54648002247A103E006B543480022
155490: 00000000000000000000000000000000 43A100F0A5F801D4012000E0002006BD
1554a0: 00000000000000000000000000000000 00B500F00BF800F00DF800F00FF800F0
1554b0: 00000000000000000000000000000000 11F800F013F800F015F800BDFFB53748
1554c0: 00000000000000000000000000000000 37A112E0FFB5354836A10EE0FFB53348
1554d0: 00000000000000000000000000000000 35A10AE0FFB5314834A106E0FFB52F48
1554e0: 00000000000000000000000000000000 33A102E0FFB52D4832A1002200F084F8
1554f0: 00000000000000000000000000000000 FFBDFFB5002001B4FFF7D2FF274828A1
155500: 00000000000000000000000000000000 26E0FFB5002001B4FFF7CAFF234825A1
155510: 00000000000000000000000000000000 1EE0FFB5002001B4FFF7C2FF1F4822A1
155520: 00000000000000000000000000000000 16E0FFB5002001B4FFF7BAFF1B481FA1
155530: 00000000000000000000000000000000 0EE0FFB5002001B4FFF7B2FF17481CA1
155540: 00000000000000000000000000000000 06E0FFB5002001B4FFF7AAFF134819A1
155550: 00000000000000000000000000000000 0422FF23813300F047F800F049F801B0
155560: 00000000000000000000000000000000 FFBDC046F35429440355294413552944
155570: 00000000000000000000000000000000 235529443355294443552944A1542944
155580: 00000000000000000000000000000000 D70500002D020000190D0000D6050000
155590: 00000000000000000000000000000000 DE0500007A0D0000400E0000D8867145
1555a0: 00000000000000000000000000000000 31000000320000003300000034000000
1555b0: 00000000000000000000000000000000 350000003600000083623845415F3845
1555c0: 00000000000000000000000000000000 C20F00001F160000004B1847ADE43145
1555d0: 00000000000000000000000000000000 004B184701173845004B184779173845
1555e0: 00000000000000000000000000000000 004B1847E183E844004D28474D7AE844
1555f0: 00000000000000000000000000000000 004D28471990E844004D28472585E844
155600: 0000000000000000 004B184759183845
;W580 SW-R8BE001
;Added 2 points in the function of 5 tab
;options-> LibEdit, Path "/card/other/Zbin/LibEdit.elf"
;Options-> DynEdit, Path "/card/other/Zbin/DynEdit.elf"
;© Mcming1989
;(p) albertnet3
45bfc814: 3068CE49CE4A00F0A7FA 004800471138CC45C046
45cc3810: 00000000000000000000000000000000 30682049204A00F08BF830680021244A
45cc3820: 00000000000000000000000000000000 00F086F81DA00621224A00F089F8021C
45cc3830: 00000000000000000000000000000000 3068002100F080F8306801211B4A00F0
45cc3840: 00000000000000000000000000000000 77F818A006211B4A00F07AF8021C3068
45cc3850: 00000000000000000000000000000000 012100F071F8354B1847FFFF00402DE9
45cc3860: 00000000000000000000000000000000 0030A0E30020A0E30010A0E37E008FE2
45cc3870: 00000000000000000000000000000000 0D0100EF0080BDE800402DE90030A0E3
45cc3880: 00000000000000000000000000000000 0020A0E30010A0E328008FE20D0100EF
45cc3890: 00000000000000000000000000000000 0080BDE8AF0F0000A906EC444C696245
45cc38a0: 00000000000000000000000000000000 6469740044796E45646974007838CC45
45cc38b0: 00000000000000000000000000000000 5C38CC45FFFF00002F00630061007200
45cc38c0: 00000000000000000000000000000000 64002F006F0074006800650072002F00
45cc38d0: 00000000000000000000000000000000 5A00420069006E002F00440079006E00
45cc38e0: 00000000000000000000000000000000 45006400690074002E0065006C006600
45cc38f0: 00000000000000000000000000000000 00002F0063006100720064002F006F00
45cc3900: 00000000000000000000000000000000 74006800650072002F005A0042006900
45cc3910: 00000000000000000000000000000000 6E002F004C0069006200450064006900
45cc3920: 00000000000000000000000000000000 74002E0065006C00660000001FC8BF45
45cc3930: 00000000000000000000000000000000 004D284701173845004D284779173845
45cc3940: 0000000000000000 004B184735743445
;W580 SW-R8BE001
;If you switch to landscape mode image icons are hiding themselves
;© Grinvich
;(p)albertnet3
45ad75b0: 192FEC44 91582944
44295890: 00000000000000000000000000000000 31B5041C00F003F8024901BC0847024B
442958a0: 000000000000000000000000 1847FFFF1D2FEC442D2EEC44
;W580 R8BE001
;Selection of menu style
;On/Off menu > More
;Choose a style
;© ZEN
;® Ploik->DB2020
;(p)albertnet3
+44140000
119c570: A0692A1CFC210901 004B9847BD532944
1553a0: 00000000000000000000000000000000 072102E0082100E00921201C00F00AF9
1553b0: 00000000000000000000000000000000 717B201C004B9847AB623845A0692A1C
1553c0: 00000000000000000000000000000000 3F21890100F002F9674A0321A06900F0
1553d0: 00000000000000000000000000000000 FDF86C4A0321A06900F0FCF8634A0421
1553e0: 00000000000000000000000000000000 A06900F0F3F8684A0421A06900F0F2F8
1553f0: 00000000000000000000000000000000 5F4A0521A06900F0E9F8644A0521A069
155400: 00000000000000000000000000000000 00F0E8F85B4A0621A06900F0DFF8604A
155410: 00000000000000000000000000000000 0621A06900F0DEF8574A0821A06900F0
155420: 00000000000000000000000000000000 D5F85C4A0821A06900F0D4F8534A0921
155430: 00000000000000000000000000000000 A06900F0CBF8584A0921A06900F0CAF8
155440: 00000000000000000000000000000000 4F4A0A21A06900F0C1F8544A0A21A069
155450: 00000000000000000000000000000000 00F0C0F8544B184706B55148002258A1
155460: 00000000000000000000000000000000 17E006B54E48002254A112E006B54C48
155470: 00000000000000000000000000000000 002251A10DE006B5494800224DA108E0
155480: 00000000000000000000000000000000 06B5474800224AA103E006B544480022
155490: 00000000000000000000000000000000 46A100F0A3F801D4012000E0002006BD
1554b0: 00000000000000000000000000000000 11F800F013F800F015F800BDFFB53848
1554c0: 00000000000000000000000000000000 3AA112E0FFB5364839A10EE0FFB53448
1554d0: 00000000000000000000000000000000 38A10AE0FFB5324837A106E0FFB53048
1554e0: 00000000000000000000000000000000 36A102E0FFB52E4835A1002200F082F8
1554f0: 00000000000000000000000000000000 FFBDFFB5002001B4FFF7D2FF28482BA1
155500: 00000000000000000000000000000000 26E0FFB5002001B4FFF7CAFF244828A1
155510: 00000000000000000000000000000000 1EE0FFB5002001B4FFF7C2FF204825A1
155520: 00000000000000000000000000000000 16E0FFB5002001B4FFF7BAFF1C4822A1
155530: 00000000000000000000000000000000 0EE0FFB5002001B4FFF7B2FF18481FA1
155540: 00000000000000000000000000000000 06E0FFB5002001B4FFF7AAFF14481CA1
155550: 00000000000000000000000000000000 0422FF23813300F045F800F047F801B0
155560: 00000000000000000000000000000000 FFBD104B1847FFFFF354294403552944
155570: 00000000000000000000000000000000 13552944235529443355294443552944
155580: 00000000000000000000000000000000 A1542944D70500002D020000190D0000
155590: 00000000000000000000000000000000 D6050000DE0500007A0D0000400E0000
1555a0: 00000000000000000000000000000000 D88671454117384579C52D4531000000
1555b0: 00000000000000000000000000000000 32000000330000003400000035000000
1555c0: 00000000000000000000000000000000 36000000004B1847ADE43145004B1847
1555d0: 00000000000000000000000000000000 01173845004B184779173845004B1847
1555e0: 00000000000000000000000000000000 E183E844004D28474D7AE844004D2847
1555f0: 00000000000000000000000000000000 1990E844004D28472585E844004B1847
155600: 00000000 C9173845
;W580 SW-R8BE001
;Melody for unknown and hidden call
;Allows you to set the tone for the unknown and hidden calls
;Put in the folder /card/music files unknown.mp3 and hidden.mp3
;In the absence of the files will play the ringing tone
;v. 1
;© IronMaster
;(p)albertnet3
44db16e6: 02D1 DED1
44db85e4: 221D201C 98475DE0
44db86c8: E81D0000 B1582944
442958b0: 00000000000000000000000000000000 FFB510A53520385C012807D0022805D0
442958c0: 00000000000000000000000000000000 12A5009880210906884212D10022291C
442958d0: 00000000000000000000000000000000 144800F02BF800280BD46E4624361249
442958e0: 00000000000000000000000000000000 706800F029F8291CB06800F025F80121
442958f0: 00000000000000000000000000000000 7170FFBD680069006400640065006E00
44295900: 00000000000000000000000000000000 2E006D00700033000000000075006E00
44295910: 00000000000000000000000000000000 6B006E006F0077006E002E006D007000
44295920: 00000000000000000000000000000000 3300000024E5874524E5874503B40148
44295930: 00000000000000000000000000000000 019001BDE183E84403B40148019001BD
44295940: 00000000 0D7EE444
;W580 SW-R8BE001
;In the "Silent" a Video Player and Radio not working
;In the rest of the field work as before
;© ZEN
;DB2010->DB2020 (p)ploik
;(p)albertnet3
44fd65cc: 002811D0012E01D1 004B984751592944
44295950: 00000000000000000000000000000000 00281BD00F4810498847002801D0002E
44295960: 00000000000000000000000000000000 0DE00E480C498847002800D0F7E70C48
44295970: 00000000000000000000000000000000 09498847002800D0F1E7012E01D00124
44295980: 00000000000000000000000000000000 04E0014B9847FFFFD965FD44004B9847
44295990: 00000000000000000000000000000000 F565FD44B508F54409CB2A45554EF344
442959a0: 00000000 09AD0F45
;W580 SW-R8BE001
;Auto power off your player and radio
;To the functions of the player and the radio added item "Self-Timer"
;Using a timer from organizer
;V3 now works with the radio, the second press disables the timer
;© ZEN
;(p)albertnet3
44f36ebc: F21D0000 51592944
44f36bde: 002805D0 C0462847
450f8bc0: A069 8847
450f8c10: B30F0000 B1592944
44dc2b72: 102041F234FE0120A875 014B9847C0460D5A2944
44295950: 00000000000000000000000000000000 244AFD21E069274B98471F4AFD21E069
44295960: 00000000000000000000000000000000 254B9847E0691521FF22244B98471E4D
44295970: 00000000000000000000000000000000 1F4B984700B5224800F001F800BD214B
44295980: 00000000000000000000000000000000 1847FFB5194846498847002805D00F48
44295990: 00000000000000000000000000000000 104FB84700F060F8FFBD1B4840498847
442959a0: 00000000000000000000000000000000 0028F7D00A480B4FB84700F055F8FFBD
442959b0: 00000000000000000000000000000000 0C4AA069132100F09FF8074AA0691321
442959c0: 00000000000000000000000000000000 00F09EF80549A069054B1847211C0000
442959d0: 00000000000000000000000000000000 221C0000D1CE2A4526030000B30F0000
442959e0: 00000000000000000000000000000000 C38B0F45435A29449E1E0000554EF344
442959f0: 00000000000000000000000000000000 E36BF344D948F3440D49F3442949F344
44295a00: 00000000000000000000000000000000 80B8BC4519F0384509AD0F4500F00EF8
44295a10: 00000000000000000000000000000000 012806D0182000F06BF80120A8752F4B
44295a20: 00000000000000000000000000000000 18470120A875FFF7ACFFF8E706B52C48
44295a30: 00000000000000000000000000000000 00222CA100F068F801D4012000E00020
44295a40: 00000000000000000000000000000000 06BDFFB5FFF7F2FF012802D000F035F8
44295a50: 00000000000000000000000000000000 FFBD00F001F8FFBDFFB5214821A10022
44295a60: 00000000000000000000000000000000 00F05EF800F001F8FFBD00B5024800F0
44295a70: 00000000000000000000000000000000 11F800F011F800BD7D5A294400B50068
44295a80: 00000000000000000000000000000000 40680A4900F00AF8002801D1012000BD
44295a90: 00000000000000000000000000000000 002000BD024B1847034B1847014B1847
44295aa0: 00000000000000000000000000000000 09CB2A45257455441D2ADC44B05A2944
44295ab0: 00000000000000000000000000000000 54696D6572426F6F6B00FFB5002001B4
44295ac0: 00000000000000000000000000000000 074808A10422FF23813300F021F800F0
44295ad0: 00000000000000000000000000000000 23F801B0FFF74EFFFFBDFFFF7D2BDC44
44295ae0: 00000000000000000000000000000000 D8867145740069006D00650072000000
44295af0: 00000000000000000000000000000000 004B1847E1470045004B184701173845
44295b00: 00000000000000000000000000000000 004B184779173845004B1847E183E844
44295b10: 00000000000000000000000000000000 004D28474D7AE844004D28471990E844
44295b20: 0000000000000000 004D28472585E844
;W580 SW-R8BE001
;Add to receiving MMS softkey "OK"
;Softkey "OK" returns you to the incoming messages
;© ZEN
;DB2010->DB2020 (p) ploik
;(p) albertnet3
4503616c: B069 8847
450361f8: AB0F0000 B15D2944
44295db0: 00000000000000000000000000000000 1149B069FFB5061C0A490E4A0B4FB847
44295dc0: 00000000000000000000000000000000 094A0849301C0A4FB847FFBD00B50448
44295dd0: 00000000000000000000000000000000 00F001F800BD014B1847FFFF19F03845
44295de0: 00000000000000000000000000000000 88BBBC45AC0F00002107000001173845
44295df0: 000000000000000000000000 79173845CD5D2944AB0F0000
;W580 SW-R8BE001
;Screensaver at the end of the voice conversations
;(c) jamesbond22
;(r) Ploik
;(e) -=Laura_P=-
;(p) albertnet3
44da4108: 1141DA44 D1622944
442962d0: 00000000000000000000000000000000 00B500F00AF800F001F800BD00B50448
442962e0: 00000000000000000000000000000000 00F001F800BD034B1847034B1847FFFF
442962f0: 000000000000000000000000 AB070000D1CE2A451141DA44
;W580 SW-R8BE001
;Office of the player
;v. 2.2
;(c) Sic
;(e)E1kolyan, MahmudS
;(p)albertnet3
44F32128: 0E1C6846057E0B290BD0 004E01E0FD92DA45B047
45DA92FC: 00000000000000000000 0D1C6846067DFFB51822
45DA9307: 000000 2935D0
45DA930B: 000000 2935D0
45DA930F: 000000 2935D0
45DA9313: 000000 2926D0
45DA9317: 000000 2916D0
45DA931B: 000000 2906D0
45DA931F: 000000 2919D0
45DA9323: 000000000000000000 2909D00B292DD02FE0
45DA932C: 00000000000000000000000000000000 20482149884700281ED01B491AE01D48
45DA933C: 00000000000000000000000000000000 1D498847002817D0194913E019481A49
45DA934C: 00000000000000000000000000000000 8847002810D013490CE0164816498847
45DA935C: 00000000000000000000000000000000 002809D0114905E01248134988470028
45DA936C: 00000000000000000000000000000000 02D00B49094FB847FFBD4A2002E04D20
45DA937C: 00000000000000000000000000000000 00E00548034FB8477622089880180890
45DA938C: 00000000000000000000000000000000 FFBDFFFFD1CE2A4548080000C5E22A45
45DA939C: 00000000000000000000000000000000 38B6AE4518B7AE4538B5AE4594B7AE45
45DA93AC: 000000000000000000000000 B4B6AE455D65F34499DC2A45
; Keys (HEX)
45DA9306: 00 15; Volume + (button 2)
45DA930A: 00 1b; Volume - (button 8)
45DA930E: 00 1e; Exit to the main screen (button #)
45DA9312: 00 1C; Play mode (button Game 9)
45DA9316: 00 16; Equalizer (button 3)
45DA931A: 00 13; File information (button 0)
45DA931E: 00 1a; Send file (button 7)
45DA9322: 00 14; Stereo widening (button 1)
;W580 SW-R8BE001
;Blacklist Reject mode
;Add "Reject mode" option to the Accept calls menu for Change blacklist reject call mode
;Reject mode contain 2 mode:
;1. Busy (send busy tone)
;2. RF on/off (the phone Not available)
;v 1.0
;© Amir_82111
;(p)albertnet3
44db5f6e: 11220021281C01F0BCFD 014A1047FFFF015F2944
44ddf7f8: 2749 9047
44ddf82c: 9DF8DD44 255F2944
44295f00: 00000000000000000000000000000000 002100F0C9F8002803D000F031F900F0
44295f10: 00000000000000000000000000000000 33F911220021281C00F032F900490847
44295f20: 00000000000000000000000000000000 795FDB44364A3749FFB5366800F001F8
44295f30: 00000000000000000000000000000000 FFBDFFB500223021301C00F029F936A0
44295f40: 00000000000000000000000000000000 06210B2200F038F9021C301C302100F0
44295f50: 00000000000000000000000000000000 23F9301C2E4A312100F01AF931A00621
44295f60: 00000000000000000000000000000000 092200F029F9021C301C312100F014F9
44295f70: 00000000000000000000000000000000 002100F091F8002801D0244A00E0224A
44295f80: 00000000000000000000000000000000 301C312100F00CF9301C3021312200F0
44295f90: 00000000000000000000000000000000 0BF9301C1F4A322100F0FAF823A00621
44295fa0: 00000000000000000000000000000000 092200F009F9021C301C322100F0F4F8
44295fb0: 00000000000000000000000000000000 002100F071F8012801D0144A00E0124A
44295fc0: 00000000000000000000000000000000 301C322100F0ECF8301C3021322200F0
44295fd0: 00000000000000000000000000000000 EBF819A00621402200F0EEF8051C2A1C
44295fe0: 00000000000000000000000000000000 301C302100F0E4F82A1C301C312100F0
44295ff0: 00000000000000000000000000000000 DFF82A1C301C322100F0DAF8FFBDFFFF
44296000: 00000000000000000000000000000000 9DF8DD44C20F000024E600005BEE0000
44296010: 00000000000000000000000000000000 756029448760294452656A656374206D
44296020: 00000000000000000000000000000000 6F6465004275737900FFFFFF5246206F
44296030: 00000000000000000000000000000000 6E2F6F666600FFFF426C61636B6C6973
44296040: 00000000000000000000000000000000 742052656A656374206D6F6465207631
44296050: 00000000000000000000000000000000 2E300A28632920416D69725F38323131
44296060: 00000000000000000000000000000000 310A28702920616C626572746E657433
44296070: 00000000000000000000000000000000 00FFFFFFFFB50121002000F00DF82E1C
44296080: 00000000000000000000000000000000 FFF757FFFFBDFFB50121012000F004F8
44296090: 00000000000000000000000000000000 2E1CFFF74EFFFFBDFEB581B06E460C1C
442960a0: 00000000000000000000000000000000 307014A01EA1002200F049F803D4012C
442960b0: 00000000000000000000000000000000 04D0012203E000203070012402220020
442960c0: 00000000000000000000000000000000 01B40CA016A1FF23813300F03DF8311C
442960d0: 00000000000000000000000000000000 051C01B0002C03D1012200F03DF802E0
442960e0: 00000000000000000000000000000000 012200F03DF8281C00F03EF8307801B0
442960f0: 00000000000000000000000000000000 FEBDFFFF2F007400700061002F007300
44296100: 00000000000000000000000000000000 79007300740065006D002F0073006500
44296110: 00000000000000000000000000000000 7400740069006E00670073000000FFFF
44296120: 00000000000000000000000000000000 520065006A006500630074006D006F00
44296130: 00000000000000000000000000000000 640065002E00620069006E000000014B
44296140: 00000000000000000000000000000000 1847FFFFE183E84408B4024B9C4608BC
44296150: 00000000000000000000000000000000 6047FFFF4D7AE844004B1847A192E844
44296160: 00000000000000000000000000000000 004B18476D94E844004B18471990E844
44296170: 00000000000000000000000000000000 00480047E95D644400480047CD5D6444
44296180: 00000000000000000000000000000000 08B4024B9C4608BC6047FFFFF17ADB44
44296190: 00000000000000000000000000000000 004B184701173845004B184779173845
442961a0: 00000000000000000000000000000000 004B184741173845004B184759183845
442961b0: 00000000000000000000000000000000 004B184765173845004B184735743445
;W580 SW-R8BE001
;RF on/off reject mode with hold button "back" when incomming call
;© Amir_82111
;(p) zapret007
44DB68C4: 096FDB44 3193da45
45DA9330: 00000000000000000000000000000000 00B500F005F81122002100F00FF800BD
45DA9340: 00000000000000000000000000000000 FFB500F003F800F005F8FFBD004A1047
45DA9350: 00000000000000000000000000000000 e95d6444004A1047cd5d644408B4024B
45DA9360: 000000000000000000000000 9C4608BC6047FFFF15d9ec44
;W580 SW-R8BE001
;On/Off Keyboard Backlight
;Options-Display-Brightness-Keyboard
;For on/off backlight keyboard after clicking on the item should be done "+","-" brightness
;© ZEN
;DB2010->DB2020 (p)Ploik
;(p) albertnet3
452de71a: 1149E069 90471049
452de74c: C5E72D45 F1612944
45391398: 152E09D2607A032806D0 004A1047C1612944C046
442961c0: 00000000000000000000000000000000 00F00BF8012806D0152E3FD2617B0329
442961d0: 00000000000000000000000000000000 3CD0204B1847992EF7E706B520480022
442961e0: 00000000000000000000000000000000 20A100F05BF801D4012000E0002006BD
442961f0: 00000000000000000000000000000000 174AE069FFB5061C2249184A00F046F8
44296200: 00000000000000000000000000000000 214A2049301C00F045F8FFBDFFB5FFF7
44296210: 00000000000000000000000000000000 E4FF012802D000F00BF8FFBD00F001F8
44296220: 00000000000000000000000000000000 FFBDFFB50E480FA1002200F043F8FFBD
44296230: 00000000000000000000000000000000 FFB5002001B40A480AA10422FF238133
44296240: 00000000000000000000000000000000 00F030F800F032F801B0FFBD024B1847
44296250: 00000000000000000000000000000000 C5E72D45A3133945B11339450D622944
44296260: 00000000000000000000000000000000 D8867145420072006900670068007400
44296270: 00000000000000000000000000000000 6E006500730073002E00620069006E00
44296280: 00000000000000000000000000000000 0000FFFFAC0F0000D8150000004B1847
44296290: 00000000000000000000000000000000 01173845004B184779173845004B1847
442962a0: 00000000000000000000000000000000 E183E844004D28474D7AE844004D2847
442962b0: 00000000000000000000000000000000 1990E844004D28472585E844004B1847
442962c0: 00000000 C9173845
;W580 SW-R8BE001
;SMS Transliter v2.0
;(!)Must put the file "character_table.ucfg" in the Config folder on the phone
;(c) Slawwan
;(p) albertnet3
;RU. Version
450e67a8: E91C9AF2A9FF E91C121C9047
450e6820: 296B0E45 D1622944
442962d0: 00000000000000000000000000000000 0A4A70B50A4D0B4E0400A8470A4A3100
442962e0: 00000000000000000000000000000000 2000A8470948564A002100F003F90200
442962f0: 00000000000000000000000000000000 3100200000F0EEF8002070BD296B0E45
44296300: 00000000000000000000000000000000 01173845C20F0000B16429443C652944
44296310: 00000000000000000000000000000000 00B50522012100F0F1F800BD00B500F0
44296320: 00000000000000000000000000000000 F1F800BDF3B5364984B000285AD00598
44296330: 00000000000000000000000000000000 00258847019006214843801CFFF7E8FF
44296340: 00000000000000000000000000000000 04000820FFF7E4FF00903A2141800098
44296350: 00000000000000000000000000000000 2021818000980026C5800420FFF7D8FF
44296360: 00000000000000000000000000000000 02900D210180029845800198012814DA
44296370: 00000000000000000000000000000000 680000212152801CFFF7CAFF05002100
44296380: 00000000000000000000000000000000 00F0ACF82000FFF7C9FF280035E00399
44296390: 00000000000000000000000000000000 680009886D1C2152761C01988642E7DA
442963a0: 00000000000000000000000000000000 05997000081803900399009809880180
442963b0: 00000000000000000000000000000000 0498009900F096F80700E8D00299871D
442963c0: 00000000000000000000000000000000 380000F08FF840087908401A0128DEDB
442963d0: 00000000000000000000000000000000 00218142E0DA4B00FB5A6A006D1CA352
442963e0: 00000000000000000000000000000000 491CF6E7059888474000801CFFF790FF
442963f0: 00000000000000000000000000000000 0599040000F072F8200006B0F0BDFFFF
44296400: 00000000000000000000000000000000 C97DE44430B582B004000D006A4601A9
44296410: 00000000000000000000000000000000 00F06CF86846008800280FD001992800
44296420: 00000000000000000000000000000000 FFF780FF064A0500002100F063F80100
44296430: 00000000000000000000000000000000 206800F06BF82800FFF770FF02B030BD
44296440: 00000000000000000000000000000000 FFFF000030B5154C87B06A4621003031
44296450: 00000000000000000000000000000000 200000F05FF80021C94388421BD00020
44296460: 00000000000000000000000000000000 01B4FF238133012221003031200000F0
44296470: 00000000000000000000000000000000 55F8040001B00ED40298801CFFF748FF
44296480: 00000000000000000000000000000000 029A05002900200000F04CF8200000F0
44296490: 00000000000000000000000000000000 4DF8280000E0002007B030BD5C652944
442964a0: 00000000000000000000000000000000 00B540690021406800F044F800BD0000
442964b0: 00000000000000000000000000000000 30B50400FFF7C6FF05000AD02000FFF7
442964c0: 00000000000000000000000000000000 EFFF002802D02900FFF79CFF2800FFF7
442964d0: 00000000000000000000000000000000 25FF30BD004B184779173845004B1847
442964e0: 00000000000000000000000000000000 4D7D5544004B18478D7E5544004B1847
442964f0: 00000000000000000000000000000000 BD6D2F45004B184735743445004B1847
44296500: 00000000000000000000000000000000 65C4F744004B1847BDDDF744004B1847
44296510: 00000000000000000000000000000000 5DCC2E45004F3847E183E844004F3847
44296520: 00000000000000000000000000000000 4D7AE844004F3847A192E844004F3847
44296530: 00000000000000000000000000000000 1990E844004B1847E95A1B45D200F000
44296540: 00000000000000000000000000000000 E000ED00F100EB00E800F200E500F000
44296550: 00000000000000000000000000000000 E000F600E800FF00000000002F007400
44296560: 00000000000000000000000000000000 700061002F0075007300650072002F00
44296570: 00000000000000000000000000000000 6F0074006800650072002F005A004200
44296580: 00000000000000000000000000000000 69006E002F0043006F006E0066006900
44296590: 00000000000000000000000000000000 67000000000063006800610072006100
442965a0: 00000000000000000000000000000000 63007400650072005F00740061006200
442965b0: 00000000000000000000000000000000 6C0065002E0075006300660067000000
Attached File  character_table.rar   346bytes   0 downloads
;W580 SW-R8BE001
;Close Radio when pressing button "Back"
;Minimize Radio when pressing "Long Back"
;© K790alex
;v.2
450F8BC8: A0692A1CFC210901 00480047110E2944
44290E10: 00000000000000000000000000000000 094A0A49A06900F00BF8094A0949A069
44290E20: 00000000000000000000000000000000 00F006F803E0F0B5074800F003F8F0BD
44290E30: 00000000000000000000000000000000 064B1847064B184721950F45C00F0000
44290E40: 00000000000000000000000000000000 270E2944AF0F00004808000001173845
44290E50: 00000000 D1CE2A45
;W580 SW-R8BE001
;Replacing folder to save screenshots from the video
;/ card / picture -> / card / picture / Video Frames
;/ tpa / user / picture -> / tpa / user / picture / Video Frames
;(!) save video frames in phone if removed memory or memory is full.
;v.2
;© amir_82111
;(p) albertnet3
44f53960: EC37 004F
44f53962: 05A9 3847
44f53964: 381C36F7 9939CC45
44f53968: 71FF C046
45aee670: 2F0063006100720064002F0070006900 2F0063006100720064002F0070006900
45aee680: 6300740075007200650000002F007400 630074007500720065002F0056006900
45aee690: 700061002F0075007300650072002F00 640065006F0020004600720061006D00
45aee6a0: 700069006300 650073000000
45cc3998: 00000000000000000000000000000000 034F05A9381C034B9847034B1847FFFF
45cc39a8: 00000000000000000000000000000000 B439CC454DA8E8446B39F5442F007400
45cc39b8: 00000000000000000000000000000000 700061002F0075007300650072002F00
45cc39c8: 00000000000000000000000000000000 70006900630074007500720065002F00
45cc39d8: 00000000000000000000000000000000 56006900640065006F00200046007200
45cc39e8: 00000000000000000000 61006D00650073000000
;W580 SW-R8BE001
;Disable reject with double press volume keys for incoming call
;© Amir_82111
;(p) -DeJaVu- a.k.a -BourNe-
44DB6EB8: 0D 10
;W580 SW-R8BE001
;Changing the size of the system font. Is made smaller - IMHO very convenient!
;© xFoX
;(p)dark_angel
;® albertnet3
45bbbe64: 45005F003200340052000000 45005F003200300052000000
;W580 SW-R8BE001
;Change list menu GUI
;© Therion
;(p)albertnet3
4531e2d4: 0021 0121
;W580 SW-R8BE001
;Addon for the patch "Privacy" v3.0 from IronMaster
;Fixed a bug with unlocking the keypad in Flight Mode (if the password is)
;(c) Mcming1989
;(p)albertnet3
45393980: 2CF786FD C046C046
;W580 R8BE001
;Replacing the phone graphics
;Ver 1.1
;In folder ini (/tpa/user/other/ini), place GFX.ini file
;In GFX.ini specify the path to replaced graphics
;Example: [GFX_Folder]: /tpa/user/other/IMG (+ enter on the end of line)
;In this folder are icons XXXX.PNG (XXXX.GIF, XXXX.JPG),
;where XXXX - hex number of replaced icon
;Ver 2.0
; -Works from phone start, not from StandbyBook
; -Icons for sysgfx and in main can have different resolutions
;(C) Joker XT
;(e) Vertexbz
;(p)LiNkMaN
+44140000
0121ECF4: 10B5041C03F00CFD04F040FA 10B5014B18470000C726C245
0121ED08: 10B5041C03F002FD04F036FA 10B5014B18470000DB26C245
01223208: BB4915AA10888842 004B1847A126C245
01AE26A0: 00000000000000000000000000000000 15AA108800F0FCF915AA108014491088
01AE26B0: 00000000000000000000000000000000 884206D315AB1A881248824201D2124B
01AE26C0: 00000000000000000000000000000000 1847124B184700F0EBF9041C00F00FF8
01AE26D0: 00000000000000000000000000000000 00F010F8211C0E4B184700F0E1F9041C
01AE26E0: 00000000000000000000000000000000 00F005F800F006F8211C0A4B18470A48
01AE26F0: 00000000000000000000000000000000 80697047011C0020002900D0486A7047
01AE2700: 00000000000000000000000000000000 01E8000000E900001F32364549323645
01AE2710: 00000000000000000000000000000000 03ED354517ED354510FE042010B50021
01AE2720: 00000000000000000000000000000000 0523040009A003B401222100002000F0
01AE2730: 00000000000000000000000000000000 F7F902B010BD000000B5002805D00023
01AE2740: 00000000000000000000000000000000 02A20100002000F0F3F900BD00000000
01AE2750: 00000000000000000000000000000000 30402DE904D04DE20040A0E10150A0E1
01AE2760: 00000000000000000000000000000000 0020A0E3F50000EB010070E30300000A
01AE2770: 00000000000000000000000000000000 0D20A0E10510A0E10400A0E1F20000EB
01AE2780: 00000000000000000000000000000000 B000DDE13280BDE8B020D0E10010A0E3
01AE2790: 00000000000000000000000000000000 2E0052E31700000AB220D0E0300052E3
01AE27A0: 00000000000000000000000000000000 0200003A400052E3D030A0330900003A
01AE27B0: 00000000000000000000000000000000 410052E30200003A470052E3C930A033
01AE27C0: 00000000000000000000000000000000 0400003A610052E30600003A670052E3
01AE27D0: 00000000000000000000000000000000 0400002AA930A0E3FF3C83E3022083E0
01AE27E0: 00000000000000000000000000000000 0228A0E12228A0E1011282E1B020D0E1
01AE27F0: 00000000000000000000000000000000 2E0052E3E7FFFF1A0100A0E11EFF2FE1
01AE2800: 00000000000000000000000000000000 F04F2DE908439FE5E4D04DE20C00A0E3
01AE2810: 00000000000000000000000000000000 C1FFFFFA000084E5FE00A0E3400F80E3
01AE2820: 00000000000000000000000000000000 BDFFFFFA001094E5000081E50010A0E1
01AE2830: 00000000000000000000000000000000 00108DE57200A0E3900E80E3B6FFFFFA
01AE2840: 00000000000000000000000000000000 001094E5040081E50010A0E104108DE5
01AE2850: 00000000000000000000000000000000 450EA0E3B0FFFFFA001094E50040A0E1
01AE2860: 00000000000000000000000000000000 080081E50000A0E34110A0E3E51C81E3
01AE2870: 00000000000000000000000000000000 FD5081E2060000EA00209DE5802082E0
01AE2880: 00000000000000000000000000000000 B010C2E1011081E20118A0E12118A0E1
01AE2890: 00000000000000000000000000000000 010080E2050051E1F6FFFF3A0000A0E3
01AE28A0: 00000000000000000000000000000000 0110A0E3EA1C81E3B860A0E3EE6C86E3
01AE28B0: 00000000000000000000000000000000 060000EA04209DE5802082E0B010C2E1
01AE28C0: 00000000000000000000000000000000 011081E20118A0E12118A0E1010080E2
01AE28D0: 00000000000000000000000000000000 060051E1F6FFFF3A0000A0E3B910A0E3
01AE28E0: 00000000000000000000000000000000 F21C81E3DF70A0E3F47C87E3050000EA
01AE28F0: 00000000000000000000000000000000 802084E0B010C2E1011081E20118A0E1
01AE2900: 00000000000000000000000000000000 2118A0E1010080E2070051E1F7FFFF3A
01AE2910: 00000000000000000000000000000000 84819FE508208DE2381088E2100088E2
01AE2920: 00000000000000000000000000000000 860000EB010070E35900000A10009DE5
01AE2930: 00000000000000000000000000000000 010080E278FFFFFA0090A0E10000A0E3
01AE2940: 00000000000000000000000000000000 01002DE9603FA0E30120A0E3381088E2
01AE2950: 00000000000000000000000000000000 100088E27F0000EB00A0B0E104D08DE2
01AE2960: 00000000000000000000000000000000 0F00000A10209DE50910A0E17C0000EB
01AE2970: 00000000000000000000000000000000 0020A0E30810A0E10900A0E17B0000EB
01AE2980: 00000000000000000000000000000000 0080B0E10400000A0810A0E124008DE2
01AE2990: 00000000000000000000000000000000 790000EB0800A0E166FFFFFA0A00A0E1
01AE29A0: 00000000000000000000000000000000 780000EB0900A0E162FFFFFA24008DE2
01AE29B0: 00000000000000000000000000000000 770000EB0080A0E16800A0E3700E80E3
01AE29C0: 00000000000000000000000000000000 55FFFFFA0090A0E10B0000EAB900A0E3
01AE29D0: 00000000000000000000000000000000 F20C80E300005AE1070000BA07005AE1
01AE29E0: 00000000000000000000000000000000 050000AA0A20A0E124008DE257FFFFEB
01AE29F0: 00000000000000000000000000000000 24119FE58A2084E0B20081E10910A0E1
01AE2A00: 00000000000000000000000000000000 0800A0E1650000EB00B0B0E11C00000A
01AE2A10: 00000000000000000000000000000000 08009BE55BFFFFEB00A0A0E1FD0045E2
01AE2A20: 00000000000000000000000000000000 00005AE1090000BA05005AE1070000AA
01AE2A30: 00000000000000000000000000000000 08109BE50A20A0E124008DE243FFFFEB
01AE2A40: 00000000000000000000000000000000 00209DE5CC109FE58A2082E0E9FFFFEA
01AE2A50: 00000000000000000000000000000000 08109BE54C0E80E200005AE1DAFFFFBA
01AE2A60: 00000000000000000000000000000000 06005AE1D8FFFFAA0A20A0E124008DE2
01AE2A70: 00000000000000000000000000000000 36FFFFEB04209DE50110E0E3751BC1E3
01AE2A80: 00000000000000000000000000000000 F0FFFFEA0800A0E1470000EB0900A0E1
01AE2A90: 00000000000000000000000000000000 28FFFFFAE4D08DE2F08FBDE8B82BC245
01AE2AA0: 00000000000000000000000000000000 30B51C4D04002868002801D1FFF7A8EE
01AE2AB0: 00000000000000000000000000000000 2A68124D1068516893686200AC4206D3
01AE2AC0: 00000000000000000000000000000000 FD35AC4203D214498018405A30BD0C48
01AE2AD0: 00000000000000000000000000000000 844206D30B48844203D20B488918085A
01AE2AE0: 00000000000000000000000000000000 30BD0A48844206D30948844203D20B48
01AE2AF0: 00000000000000000000000000000000 9918085A30BD200030BDC04641E50000
01AE2B00: 00000000000000000000000000000000 01EA0000B8EE0000FE2BFEFFB9F20000
01AE2B10: 00000000000000000000000000000000 DFF4000028421A207E35FEFF8E1AFEFF
01AE2B20: 00000000000000000000000000000000 08B4024B9C4608BC6047C046F112F444
01AE2B30: 00000000000000000000000000000000 08B4024B9C4608BC6047C0468D100445
01AE2B40: 00000000000000000000000000000000 00C09FE51CFF2FE1E183E84400C09FE5
01AE2B50: 00000000000000000000000000000000 1CFF2FE141CAE34400C09FE51CFF2FE1
01AE2B60: 00000000000000000000000000000000 4D7AE84400C09FE51CFF2FE1A192E844
01AE2B70: 00000000000000000000000000000000 00C09FE51CFF2FE199CB274500C09FE5
01AE2B80: 00000000000000000000000000000000 1CFF2FE19190E44400C09FE51CFF2FE1
01AE2B90: 00000000000000000000000000000000 1990E84400C09FE51CFF2FE1015AE844
01AE2BA0: 00000000000000000000000000000000 00C09FE51CFF2FE1C15BE84400C09FE5
01AE2BB0: 00000000000000000000000000000000 1CFF2FE13D5DE8445B4746585F466F6C
01AE2BC0: 00000000000000000000000000000000 6465725D000000002F00740070006100
01AE2BD0: 00000000000000000000000000000000 2F0075007300650072002F006F007400
01AE2BE0: 00000000000000000000000000000000 6800650072002F0069006E0069000000
01AE2BF0: 00000000000000000000000000000000 4700460058002E0069006E0069000000
;W580 SW-R8BE001
;Sleepmode when pressing Volume +. Pressing again deactivates sleepmode
;Keylock when you press the Volume -. Pressing again unlocks the keyboard
;For the player, radio, video player button Volume + / - perform standard actions
;(c) Grinvich
;(p)albertnet3
452ade3e: 2CD0122C2CD01F2C1ED0 014B1847C046393BCC45
45cc3b38: 00000000000000000000000000000000 05D0122C1BD01F2C42D0224B18472248
45cc3b48: 00000000000000000000000000000000 00F036F8002837D1224800F031F80028
45cc3b58: 00000000000000000000000000000000 32D11F4800F02CF800282DD11E4800F0
45cc3b68: 00000000000000000000000000000000 27F800281FD1224800F024F81FE01648
45cc3b78: 00000000000000000000000000000000 00F01EF8002821D1164800F019F80028
45cc3b88: 00000000000000000000000000000000 1CD1134800F014F8002817D10F4800F0
45cc3b98: 00000000000000000000000000000000 0FF8002803D1194800F00CF807E01548
45cc3ba8: 00000000000000000000000000000000 00F008F803E0144800F004F8FFE738BD
45cc3bb8: 00000000000000000000000000000000 0A4B18470A4B18470A4B18470A4B1847
45cc3bc8: 00000000000000000000000000000000 0A4B184749DE2A4509AD0F4525413945
45cc3bd8: 00000000000000000000000000000000 5D65F344B508F544A540394509CB2A45
45cc3be8: 00000000000000000000000000000000 D1CE2A459BDE2A459FDE2A4587DE2A45
45cc3bf8: 00000000000000000000000000000000 AF070000B4070000B0070000B3070000
;W580 SW-R8BF001
;Change type of menu On / Off
;© Therion
;(p) albertnet3
452DC528: 0221 0921 ;Style GUI
452DC530: 0121 0021 ;Add / remove header
;452DC538: 0021 0221 ;Style it is conflict with change on /off menu style, mod 1.5 by k790alex
;W580 SW-R8BE001
;Change system fonts
;(c) Therion
;(p) Pakoko
;Original idea by xFoX
;v1.0
45BBBE68: 3200340052 3100360052
;E_24I - 3200340049
;E_24B - 3200340042
;E_24R - 3200340052
;E_20I - 3200300049
;E_20R - 3200300052
;E_16I - 3100360049
;E_16B - 3100360042
;E_14B - 3100340042
;E_14R - 3100340052
;E_12B - 3100320042
;E_12R - 3100320052
;E_8R - 3800520000
;W580 R8BE001
;Automatic recording of Voice Call
;(i) Heap shift (201A4078 - 201A407C)
;(c) Sic
;(p) MILAD
+44140000
C615C0: 211C A847
C61634: 211C A847
C6163C: 211C A847
C61814: 580D0000 012ACF45
E17E1E: 2418 8047
E17E44: 3C080000 112ACF45
E18552: 82200001201884B06A46 0148804701E0592ACF45
E185C4: C10F0000 BF0F0000
C6BEBA: 201C00F0D2FA 2F4880470000
C6BF72: 012000BD0000 F9E73B2ACF45
C6EB58: 059F 9847
C6EBAC: 0C870420 892ACF45
1bb2a00: 00000000000000000000000000000000 264D211CFFB50A2005A10131244F33E0
1bb2a10: 00000000000000000000000000000000 24482418FFB5002100F03CF82DE0FFFF
1bb2a20: 00000000000000000000000000000000 FFB5012100F036F800201F4FB8477D20
1bb2a30: 00000000000000000000000000000000 C00012A101311A4F1EE0FFB51B481C4F
1bb2a40: 00000000000000000000000000000000 B847002805D1184FB847012100F022F8
1bb2a50: 00000000000000000000000000000000 13E00021174F0FE082200001201884B0
1bb2a60: 00000000000000000000000000000000 6A46FFB5144FB847002806D030681349
1bb2a70: 00000000000000000000000000000000 02A20132124B134FB847FFBDFFB51248
1bb2a80: 00000000000000000000000000000000 0068124FB847E4E7114B059FFFB50E4B
1bb2a90: 00000000000000000000000000000000 1C60F2E7FFB50F480F4FEDE7580D0000
1bb2aa0: 00000000000000000000000000000000 05B42A453C08000065C4DA44497EF544
1bb2ab0: 00000000000000000000000000000000 09CB2A45F5E62A4559F9DA44AB0F0000
1bb2ac0: 00000000000000000000000000000000 2C0600004990F54478401A20D5CA2A45
1bb2ad0: 000000000000000000000000 8C8704202AF40000CD382C45
;W580 SW-R8BE001
;Remove voice recorder beep
;v.2
;(c)SiNgle
;(p)-=Tanusha_SE=-
45AEEE20: 1E 00
45AEEE3C: 14 00
44F5893D: D2 E0
44F58981: D1 E0
;W580 SW-R8BE001
;Changing Operator Logo
;Put file "LOGO.ini" in the folder "/ tpa / user / other / ini"
;example of LOGO.ini:
;[LOGO]: 0x3
;Use elves to edit a file
;v1.0 Beta
;© k790alex
;® Sic
;(p) albertnet3
452c36a2: 83F05FFF021CF0690121 0148804701E081D5C545
45c5d580: 00000000000000000000000000000000 F0690121FFB544A000F014F8012805D0
45c5d590: 00000000000000000000000000000000 022805D0032805D05BA004E040A002E0
45c5d5a0: 00000000000000000000000000000000 47A000E050A00021FF22224DA8470290
45c5d5b0: 00000000000000000000000000000000 FFBDFFFFF0B5061C002490B000200090
45c5d5c0: 00000000000000000000000000000000 24A168461D4FB8472DA1B847684631A1
45c5d5d0: 00000000000000000000000000000000 1C4FB847C0B0051C29D02B1C0122FF21
45c5d5e0: 00000000000000000000000000000000 01316846184FB847281C184FB847311C
45c5d5f0: 00000000000000000000000000000000 00226846104FB847051C7821144FB847
45c5d600: 00000000000000000000000000000000 00280FD00130021C002013783B2B08D0
45c5d610: 00000000000000000000000000000000 402B00DB09331B071B0F000118430132
45c5d620: 00000000000000000000000000000000 F3E7041C281C064FB847201C00E00020
45c5d630: 00000000000000000000000000000000 50B0F0BD3574344599CB2745F17C5544
45c5d640: 00000000000000000000000000000000 6D0C28451D381B45CD301B45792E1B45
45c5d650: 00000000000000000000000000000000 0D7455442F007400700061002F007500
45c5d660: 00000000000000000000000000000000 7300650072002F006F00740068006500
45c5d670: 00000000000000000000000000000000 72002F0069006E0069002F0000000000
45c5d680: 00000000000000000000000000000000 4C004F0047004F002E0069006E006900
45c5d690: 00000000000000000000000000000000 0000FFFF726200005B4C4F474F5D0000
;name 0x1
45c5d6a0: 00000000000000000000000000000000 53004500200057003500380030006900 ;"SE W580i"
45c5d6b0: 00000000000000000000000000000000 0000000000000000000000000000FFFF
;name 0x2
45c5d6c0: 00000000000000000000000000000000 61006C0062006500720074006E006500 ;"albertnet3"
45c5d6d0: 00000000000000000000000000000000 74003300000000000000000000000000
;name 0x3
45c5d6e0: 00000000000000000000000000000000 000000000000FFFF5700350038003000 ;"W580i"
45c5d6f0: 00000000000000000000000000000000 69000000000000000000000000000000
;name 0x4
45c5d700: 0000000000000000000000000000 000000000000FFFF3B0029000000 ;";)"
Changing Operator Logo v. 1.0 beta .ini: Attached File  Changing Operator Logo v. 1.0 beta.rar   252bytes   0 downloads
;W580 SW-R8BE001
;Adding icons in Notes
;(c) michlantecuhtli
;(p)albertnet3
44e251ca: 1836B268371C101C1268 014B1847FFFFB1482944
44e25454: 60EB0000 8FEC0000
442948b0: 00000000000000000000000000000000 084A0021201C00F007F81836B268371C
442948c0: 00000000000000000000000000000000 101C1268024B1847004B18471DF03145
442948d0: 0000000000000000 D551E2448BEC0000
;W580 SW-R8BE001
;Equalizer border color level
;(c) Va_st
;(p) albertnet3
44F329D4: 0000FF ******
;replace ****** with desired color
;W580 SW-R8BE001
;System font become italic
;(c) bimasakti85
;(p) albertnet3
45BBBE6C: 52 49
45BBBE84: 49 52
;W580 SW-R8BE001
;Clear Lock / Unlock keyboard (* + right soft) v2
;now standard unit keyboard (* + right soft) does not work unless enabled elf AdvKeyLock
;(c) CyberMaster
;(p)albertnet3
45bcf9f0: 79483945 3B492944
45393aac: 0022111CE9F73EFC 004A10474D492944
452bfb6e: 041C00252E1C80277F00 014F3847FFFF21492944
44294920: 00000000000000000000000000000000 041C00252E1CFF27013700F01DF80028
44294930: 00000000000000000000000000000000 01D01A4F38471848004760B5012600F0
44294940: 00000000000000000000000000000000 13F8002E01D1194DA84760BD0025051C
44294950: 00000000000000000000000000000000 002000F009F8002804D1281C0022111C
44294960: 00000000000000000000000000000000 134DA847134A10473EB50D4C0E48A047
44294970: 00000000000000000000000000000000 012E01D1002636183EBD00B5002806D0
44294980: 00000000000000000000000000000000 006840680CA1074B9847002801D00020
44294990: 00000000000000000000000000000000 00BD012000BDFFFF7FFB2B45CDFB2B45
442949a0: 00000000000000000000000000000000 99DC2A45257455447B49294479483945
442949b0: 00000000000000000000000000000000 31D33745B53A39454164764B65794C6F
442949c0: 000000 636B00
;W580 SW-R8BE001
;Disable prompt to update the time
;Time will be updated immediately, without query. (If the option is enabled)
;(c) McG
;(p) albertnet3
44DBE728: 42D0 42E0
;W580 SW-R8BE001
;Enable the transfer of java-applications
;(c) IronMaster
;(p) albertnet3
44e86fa4: 9847051C 00250D60
;W580 SW-R8BE001
;Hide Window "All contents of the Memory Stick will be deleted! Format?"
;(C) E1kolyan
;(p) albertnet3
45215836: 54F199FE C046C046
;W580 SW-R8BE001
;On/off hours images by pressing the joystick in Sleepmode
;Pressing the joystick make hours appera, pressing it again will clear the screen, now you can get
out of Sleepmode when you press softa, numeric keypad and some others
;v. 1
;(c) IronMaster
;(p)albertnet3
44850fd4: 004B1847 D1492944
45237816: 1BE0 14E0; Commented out if you need a way out of Sleepmode old way
442949d0: 00000000000000000000000000000000 F0B5041C0D1C082910D1059A002A0DD1
442949e0: 00000000000000000000000000000000 FF22493280180188002905D005498847
442949f0: 00000000000000000000000000000000 211C06488047F0BD201C1121024CA047
44294a00: 00000000000000000000000000000000 F0BDFFFF91B42A45B5303945A9293945
;W580 SW-R8BE001
;Remove message Saved in Drafts
;(c) jamesbond22
;(p)albernet3
45041110: 1FD0 1FE0
;W580 SW-R8BE001
;Replacing the background while watching videos in vertical mode
;(c) jamesbond22
;(p)albertnet3
44f4ef78: 069C151CB434FF210906 00480047314A2944C046
44294a30: 00000000000000000000000000000000 0C9C151CB4340249004B184783EFF444
44294a40: 00000000 CCCCCCFF
;W580 SW-R8BE001
;Delete "Games", "My applications" from file manager
;(c) diezil
;(p) albertnet3
45AD6550: A860AD45 00000000
45AD6554: C060AD45 00000000
;W580 SW-R8BE001
;Ability to cancel the sending of SMS-message
;When sending to the window "Sending message" is added the "Cancel" on the right softkey
;+ added the "Close" on the left softkey
;Ver 2.0
;(c) Joker XT
;(p)albertnet3
4505aa2c: A069FA21C9001AF3ADFAA069 014FB84702E0FFFF814B2944
44294b80: 00000000000000000000000000000000 FEB5134AA06911490B4FB847114AA069
44294b90: 00000000000000000000000000000000 0E490A4FB8470B4AA0690B49064FB847
44294ba0: 00000000000000000000000000000000 0D4AA0690849054FB847A0690B49044F
44294bb0: 00000000000000000000000000000000 B847A069FEBDFFFF0117384579173845
44294bc0: 00000000000000000000000000000000 914F374569AA0545BF0F0000A00F0000
44294bd0: 000000000000000000000000 45CA03459E08000075030000
;Time to display window
44294bdc: 00000000 A00F0000; time to display window 0xFA0 = 4000ms = 4s
;W580 SW-R8BE001
;Set a password to access the window of alarm clock
;When the alarm goes off the window asks for a password
;If successful an alarm clock can be turned off / put on repeat
;When you enter the wrong password an alarm clock rings again
;Passwords alarm does not stop, the default password "1234"
;v1.0 fix
;© 2007KrasH
;(p)albertnet3
44db9890: A99CDB44 CF692944
44db9dca: 3C2903D03B2901D0FFF7 014B1847FFFFC1692944
442969c0: 00000000000000000000000000000000 3C2903D03B2901D000F001F800BDF0B5
442969d0: 00000000000000000000000000000000 041C051C18352868002802D000F044F8
442969e0: 00000000000000000000000000000000 2860201C00F042F82860002822D03D49
442969f0: 00000000000000000000000000000000 00F03EF84521286800F03CF83A492868
44296a00: 00000000000000000000000000000000 00F03AF80421286800F038F804212868
44296a10: 00000000000000000000000000000000 00F036F80121286800F034F800212868
44296a20: 00000000000000000000000000000000 00F032F8314A3249286800F02FF82868
44296a30: 00000000000000000000000000000000 00F02EF8F0BDF0B582B0041C01AA6946
44296a40: 00000000000000000000000000000000 806900F027F800982AA100F025F80028
44296a50: 00000000000000000000000000000000 05D02349201C00F021F802B0F0BD201C
44296a60: 00000000000000000000000000000000 00F01EF802B0F0BD0E4B18470E4B1847
44296a70: 00000000000000000000000000000000 0E4B18470E4B18470E4B18470E4B1847
44296a80: 00000000000000000000000000000000 0E4B18470E4B18470E4B18470E4B1847
44296a90: 00000000000000000000000000000000 0E4B18470E4B18470E4B18470E4B1847
44296aa0: 00000000000000000000000000000000 0E4B1847294C364555642F45C9533645
44296ab0: 00000000000000000000000000000000 6D6E2F45496F2F453D6E2F45456D2F45
44296ac0: 00000000000000000000000000000000 AD6D2F45B96E2F4501173845994E3645
44296ad0: 00000000000000000000000000000000 BD6D2F45A190E444C5E12A45A99CDB44
44296ae0: 00000000000000000000000000000000 3C49AA452A070000FFFFFF6F376A2944
44296af0: 00000000 AC0F0000
44296af4: 00000000 31323334; password(1234)
;Replace ? to the correct password. The values of numbers:
;0 - 30
;1 - 31
;2 - 32
;3 - 33
;4 - 34
;5 - 35
;6 - 36
;7 - 37
;8 - 38
;9 - 39
;W580 SW-R8BE001
;Remove the restriction on the transfer of files in the File Manager in "Flight Mode" switched off Bluetooth
;v.1.0 fix
;© KrasH
;(p)albertnet3
44D8436A: 0BD0 0FE0
;W580 SW-R8BE001
;Ability to enable \ disable deleting messages
;Disable with a combination of keys <> * <>
;Combination works only in Standby
;(c) Grinvich
;(p) albertnet3
45bab270: BEB1BA45 149ADA45
45bab274: 06000000 05000000 ;characters combinations
45bab278: 29F12B45 2599DA45
45033e88: 6B4A00E0 6B4B9847
45034038: 15710445 E198DA45
4503423e: 124A3349 124B9847
45034288: 91420345 F598DA45
450342c6: 104A1149 104B9847
45034308: 1D430345 0D99DA45
45da98e0: 00000000000000000000000000000000 00F054F8002802D0414A344B1847364A
45da98f0: 00000000000000000000000000000000 324B184700F04AF8002803D03C4A3A49
45da9900: 00000000000000000000000000000000 2F4B1847314A38492D4B184700F03EF8
45da9910: 00000000000000000000000000000000 002803D0364A34492A4B18472C4A3249
45da9920: 00000000000000000000000000000000 284B184700F032F8002800D00FE0FFB5
45da9930: 00000000000000000000000000000000 00F016F8002001B42C4826A10422FF23
45da9940: 00000000000000000000000000000000 813300F05BF800F05DF801B0FFBDFFB5
45da9950: 00000000000000000000000000000000 264820A1002200F059F800F00CF8FFBD
45da9960: 00000000000000000000000000000000 1FB500200F4A03B4104912480123124C
45da9970: 00000000000000000000000000000000 A04702B01FBD1FB500200B4A03B40C49
45da9980: 00000000000000000000000000000000 0C4801230C4CA04702B01FBD06B51748
45da9990: 00000000000000000000000000000000 002210A100F02EF801D4012000E00020
45da99a0: 00000000000000000000000000000000 06BDFFFF57EA000058EA0000AD0B0000
45da99b0: 00000000000000000000000000000000 AE0B0000FFFFFF6F7D982B458F3E0345
45da99c0: 00000000000000000000000000000000 43420345CB4203451571044591420345
45da99d0: 00000000000000000000000000000000 1D43034553006D0053005F0064002E00
45da99e0: 00000000000000000000000000000000 620069006E000000C50F0000D8867145
45da99f0: 00000000000000000000000000000000 21710445004B1847E183E844004D2847
45da9a00: 00000000000000000000000000000000 4D7AE844004D28471990E844004D2847
45da9a10: 0000000000000000000000000000 2585E8440F000B001D000F000B00 ;combination of keys <> * <>
;W580 SW-R8BE001
;Vibra in 55 th second of each minute in a call
;(c) Sic
;(p) albertnet3
44e93ca8: 1D2A3645 A195DA45
45da95a0: 00000000000000000000000000000000 FFB5114EB047114870451BD138686946
45da95b0: 00000000000000000000000000000000 FF220F4FB8476D46E87A352812D1287B
45da95c0: 00000000000000000000000000000000 35280FD1002081B00090A2B068460949
45da95d0: 00000000000000000000000000000000 8847FF2132220B1C0668FF2469343659
45da95e0: 00000000000000000000000000000000 B04723B0FFBDFFFF1D2A364513C7F744
45da95f0: 0000000000000000 C9783445D51C2E45
;W580 SW-R8BE001
;Change file information
;Now in the "Location:" the full path to the file
;v. 2
;(c) Joker XT
;(p) albertnet3
44eb60da: 0028 03E0
44ecba08: 044900B5BFF7D4F8 004B18476195DA45
45da9560: 00000000000000000000000000000000 FEB582B0061C00F00FF8021C0021301C
45da9570: 00000000000000000000000000000000 00F00CF8019008480090022205216846
45da9580: 00000000000000000000000000000000 00F004F802B0FEBD014B1847014E3047
45da9590: 000000000000000000000000 C97DE444357434450A0000
;W580 SW-R8BE001
;Vibra Music
;Add item "Vibra Music" to Media Player
;When the item is actived On/Off short vibrations
;For turn off the Vibra Music is need kill AudioPlayerBook
;© K790Alex
;(p) albertnet3
;V.1.1
44f36c60: 002805D0 C0462847
44f36ee4: A4100000 D110DB45
45db10d0: 00000000000000000000000000000000 0E4A5021E0690E4B98470EA00021FF22
45db10e0: 00000000000000000000000000000000 124B9847021C5021E069114B98471148
45db10f0: 00000000000000000000000000000000 0621FF220D4B9847051C2A1C5021E069
45db1100: 00000000000000000000000000000000 0D4B98470D4D0E4B1847C0464511DB45
45db1110: 00000000000000000000000000000000 D948F344560069006200720061002000
45db1120: 00000000000000000000000000000000 4D007500730069006300000035743445
45db1130: 00000000000000000000000000000000 0D49F3449C11DB452949F344AD100000
45db1140: 00000000000000000000000000000000 656CF344FFB53020202110220C4B9847
45db1150: 00000000000000000000000000000000 7F200C490C4B9847FFBDFFB500200B4B
45db1160: 00000000000000000000000000000000 984750200A49084B9847FFBDFFB50948
45db1170: 00000000000000000000000000000000 094B9847002801D0FFF7E4FFFFBDC046
45db1180: 00000000000000000000000000000000 4D60FD445B11DB4505B42A452161FD44
45db1190: 00000000000000000000000000000000 6D11DB45554EF34409CB2A45466F7220
45db11a0: 00000000000000000000000000000000 7475726E206F66662074686520566962
45db11b0: 00000000000000000000000000000000 7261204D757369630A4973206E656564
45db11c0: 00000000000000000000000000000000 206B696C6C20417564696F506C617965
45db11d0: 000000000000 72426F6F6B00
;W580 R8be001
;Advanced snooze alarm
;Add ability to change snooze time for every alarm
;You can input snooze time in third tab in alarm's settings
;heapshift (0x201A4124-0x201A4127)
;(c) RandoM
;(e) albertnet3 (translated to english)
44dbc9f4: 022F 032F
44dbca00: 0221 0321
44dbca8c: 022E 032E
44dbcaa4: 0651AA45 8823C145
44dbbfe8: 1A9D5835002F00D074E1 004D28470123C145C046
44dbb84c: 70880028308812D1 004800479923C145
44d46d84: 01A9872292008018 004908471925C145
44dbbdfc: 211C012000F05CFE00E0 004908472D25C145C046
44dba248: 104B0E4A30B5 104B1847C046
44dba28c: A272BA45 D125C145
45c12300: 00000000000000000000000000000000 1A9D5835002F13D0012F13D00121201C
45c12310: 00000000000000000000000000000000 0B4B984701221FA1201C0A4B984700F0
45c12320: 00000000000000000000000000000000 17F8021C0021201C074B984707490847
45c12330: 00000000000000000000000000000000 0149084701490847F3BFDB44DDC2DB44
45c12340: 00000000000000000000000000000000 71E43145A5E5314565E8314587C2DB44
45c12350: 00000000000000000000000000000000 FEB585B02A8CE84FBB78002B02D05D1E
45c12360: 00000000000000000000000000000000 95420CD0521CBA70012000F095F9FF28
45c12370: 00000000000000000000000000000000 03D0694600F0A8F900E0002038803888
45c12380: 00000000000000000000000000000000 00F054F905B0FEBD57F356F35DF35CF3
45c12390: 00000000000000000000000000000000 9DEE9EEE9B1C0000708800280BD00128
45c123a0: 00000000000000000000000000000000 0CD0022806D13088002803D1201C39A1
45c123b0: 00000000000000000000000000000000 4E4B984770BD3088024B18473088024B
45c123c0: 00000000000000000000000000000000 1847FFFF55B8DB447BB8DB4411B58869
45c123d0: 00000000000000000000000000000000 0C1C002803D0324B98470020A061C648
45c123e0: 00000000000000000000000000000000 0088002801D10920000200900023221C
45c123f0: 00000000000000000000000000000000 2C4901200FB42C4B04AA2C4900200FB4
45c12400: 00000000000000000000000000000000 2B4B2C4A2C492D4803B42D49002000F0
45c12410: 00000000000000000000000000000000 30F80AB0A061002803D1201C2A4B9847
45c12420: 00000000000000000000000000000000 13E02A490AA20132294B9847A0693F21
45c12430: 00000000000000000000000000000000 8901284A264B9847A0692749274A244B
45c12440: 00000000000000000000000000000000 98472749A069274B9847012018BDFFFF
45c12450: 00000000000000000000000000000000 FFB5041C081C244B9847A74B19888142
45c12460: 00000000000000000000000000000000 02D001211880D9702149201C1F4B9847
45c12470: 00000000000000000000000000000000 FFBD08B4134B9C4608BC604707000000
45c12480: 00000000000000000000000000000000 CD23C1450800000051AFDB4400000000
45c12490: 00000000000000000000000000000000 00000000F424C145000000007C24C145
45c124a0: 00000000000000000000000000000000 294C3645A272BA452673BA45C272BA45
45c124b0: 00000000000000000000000000000000 0C73BA45011A00002473BA45FFFFFF6F
45c124c0: 00000000000000000000000000000000 2A73BA451954374565EA2A45BF0F0000
45c124d0: 00000000000000000000000000000000 01173845CDD0DB44AF0F000009BFDB44
45c124e0: 00000000000000000000000000000000 48EB0000A54F364561563745C5E12A45
45c124f0: 00000000000000000000000000000000 984EAA45436C6F636B426F6F6B5F5365
45c12500: 00000000000000000000000000000000 74416C61726D5F536E6F6F7A65456469
45c12510: 00000000000000000000000000000000 745F5061676500FF221C00F013F801A9
45c12520: 00000000000000000000000000000000 8018014B1847FFFF8D6DD44400F02FF8
45c12530: 00000000000000000000000000000000 211C0120014B9847014B1847BDCADB44
45c12540: 00000000000000000000000000000000 09BEDB44FBB585B0012000F0A5F8FF28
45c12550: 00000000000000000000000000000000 02D18722920010E0521C694600F0B4F8
45c12560: 00000000000000000000000000000000 0028F6D0002208600878002801D000F0
45c12570: 00000000000000000000000000000000 06F84878801800F002F805B0FBBD8700
45c12580: 00000000000000000000000000000000 C60005014401BF192D197A197047FFB5
45c12590: 00000000000000000000000000000000 85B0002700970197029703970497564D
45c125a0: 00000000000000000000000000000000 E878AA78002811D0012000F075F8FF28
45c125b0: 00000000000000000000000000000000 02D0694600F088F86946521E93002888
45c125c0: 00000000000000000000000000000000 C850022000F068F800F08CF805B0FFBD
45c125d0: 00000000000000000000000000000000 144B30B500F004F8004D28474FA2DB44
45c125e0: 00000000000000000000000000000000 FBB585B00C1C012000F056F8FF2801D1
45c125f0: 00000000000000000000000000000000 0D4A15E0E28D521C694600F065F80028
45c12600: 00000000000000000000000000000000 F6D000F013F8019053A000212322214B
45c12610: 00000000000000000000000000000000 984700906846052102221E4B9847021C
45c12620: 00000000000000000000000000000000 05B0FBBDA272BA45A91C0000FEB58BB0
45c12630: 00000000000000000000000000000000 01AF0025002812D00090684600780028
45c12640: 00000000000000000000000000000000 0FD0114A904738607821090620317960
45c12650: 00000000000000000000000000000000 0E48B860F96010203F18043501E00920
45c12660: 00000000000000000000000000000000 01E068464078084A9047386078200006
45c12670: 00000000000000000000000000000000 203078600648B860033501A805212A1C
45c12680: 00000000000000000000000000000000 044B98470BB0FEBD8171344562010000
45c12690: 00000000000000000000000000000000 6301000035743445FEB5071C022806D0
45c126a0: 00000000000000000000000000000000 1BA026A10022154B984700280AD40020
45c126b0: 00000000000000000000000000000000 01B4FF2381333A1C20A115A0104DA847
45c126c0: 00000000000000000000000000000000 01B000E0FF20FEBDFEB5521E171C0E1C
45c126d0: 00000000000000000000000000000000 051C14220B4B9847281C0C4B9847B900
45c126e0: 00000000000000000000000000000000 7058FEBDFFB5051C1422074B9847281C
45c126f0: 00000000000000000000000000000000 064B9847FFBDFFFF24411A20E183E844
45c12700: 00000000000000000000000000000000 4D7AE844A192E8446D94E8441990E844
45c12710: 00000000000000000000000000000000 2F007400700061002F00730079007300
45c12720: 00000000000000000000000000000000 740065006D002F007300650074007400
45c12730: 00000000000000000000000000000000 69006E00670073000000FFFF73006E00
45c12740: 00000000000000000000000000000000 6F006F007A0065006300660067002E00
45c12750: 00000000000000000000000000000000 620069006E00000059006F007500B400
45c12760: 00000000000000000000000000000000 760065002000730065006C0065006300
45c12770: 00000000000000000000000000000000 7400650064002000730069006C006500
45c12780: 00000000000000000000000000000000 6E0063006500200074006F0020006100
45c12790: 00000000000000000000000000000000 6C00610072006D002000620079000000
;W580 SW-R8BE001
;Information about voltage and temperature
;Display info of voltage and temperature of the battery during charging and from Standby
;Show info - long pressing Volume -
;(c) blacklizard
;(p) A2->DB2020 nagmet
;(P) albertnet3
45b10b54: 65E1FF44 913BC145
45c13b90: 00000000000000000000000000000000 2148F0B5214D8544020C0021204F2800
45c13ba0: 00000000000000000000000000000000 00F042F8040001A9012000F041F80798
45c13bb0: 00000000000000000000000000000000 6946009009790298069E07290BD10100
45c13bc0: 00000000000000000000000000000000 300003B4029B24352A00390010A800F0
45c13bd0: 00000000000000000000000000000000 33F802B00CE00A9B059A0499A0350FB4
45c13be0: 00000000000000000000000000000000 40B42A00059B390013A800F025F805B0
45c13bf0: 00000000000000000000000000000000 0C4A00210EA800F017F8050000210020
45c13c00: 00000000000000000000000000000000 03B4022302002000290000F01DF88120
45c13c10: 00000000000000000000000000000000 00018544F0BDC046F8F7FFFF583CC145
45c13c20: 00000000000000000000000000000000 E7030000FFFF0000004B184735743445
45c13c30: 00000000000000000000000000000000 004B1847895C9C4408B4024B9C4608BC
45c13c40: 00000000000000000000000000000000 6047C0464176554408B4024B9C4608BC
45c13c50: 00000000000000000000000000000000 6047C0467D982B455300790073007400
45c13c60: 00000000000000000000000000000000 65006D002F00540065006D0070002000
45c13c70: 00000000000000000000000000000000 49006E0066006F000000000053007900
45c13c80: 00000000000000000000000000000000 7300740065006D002000540065006D00
45c13c90: 00000000000000000000000000000000 70003A002000250064002000B0004300
45c13ca0: 00000000000000000000000000000000 0A004200610074007400650072007900
45c13cb0: 00000000000000000000000000000000 2000540065006D0070003A0020002500
45c13cc0: 00000000000000000000000000000000 64002000B00043000A00420061007400
45c13cd0: 00000000000000000000000000000000 7400650072007900200056006F006C00
45c13ce0: 00000000000000000000000000000000 74006100670065003A00200025006400
45c13cf0: 00000000000000000000000000000000 20006D00560000005300790073007400
45c13d00: 00000000000000000000000000000000 65006D002000540065006D0070003A00
45c13d10: 00000000000000000000000000000000 2000250064002000B00043000A004200
45c13d20: 00000000000000000000000000000000 61007400740065007200790020005400
45c13d30: 00000000000000000000000000000000 65006D0070003A002000250064002000
45c13d40: 00000000000000000000000000000000 B00043000A0042006100740074006500
45c13d50: 00000000000000000000000000000000 72007900200056006F006C0074006100
45c13d60: 00000000000000000000000000000000 670065003A0020002500640020006D00
45c13d70: 00000000000000000000000000000000 56000A00430068006100720067006500
45c13d80: 00000000000000000000000000000000 72002000430075007200720065006E00
45c13d90: 00000000000000000000000000000000 74003A0020002500640020006D004100
45c13da0: 00000000000000000000000000000000 0A00430075007200720065006E007400
45c13db0: 00000000000000000000000000000000 200054006F0020004200610074007400
45c13dc0: 00000000000000000000000000000000 6500720079003A002000250064002000
45c13dd0: 00000000000000000000000000000000 6D0041000A0050006F00770065007200
45c13de0: 00000000000000000000000000000000 20004400690073007300690070006100
45c13df0: 00000000000000000000000000000000 740069006F006E003A00200025006400
45c13e00: 0000000000000000 20006D0057000000
;W580 SW-R8BE001
;Ability to set the radio on full screen and back
;With softkeys, delete the background
;(i) The background does not disappear immediately, but just click "function", and it will
;(c) Ploik
;(p) albertnet3
44f993fa: 9919 1047
44f99460: 65E10122 673AC145
44f99118: C427FF00E01990F0 00480047413AC145
45c13a40: 00000000000000000000000000000000 386800F097F800F02FF8002801D00421
45c13a50: 00000000000000000000000000000000 00E00121386800F089F82978386800F0
45c13a60: 00000000000000000000000000000000 91F82F4B184700F01FF800280AD0284A
45c13a70: 00000000000000000000000000000000 1421A06900F062F8264A1421A06900F0
45c13a80: 00000000000000000000000000000000 61F809E0214A1421A06900F057F8224A
45c13a90: 00000000000000000000000000000000 1421A06900F056F8014A02491F4B1847
45c13aa0: 00000000000000000000000000000000 21950F45AF0F000006B51E4800221EA1
45c13ab0: 00000000000000000000000000000000 00F04CF801D4012000E0002006BD10B5
45c13ac0: 00000000000000000000000000000000 041C00F001F819E0FFB5164816A10022
45c13ad0: 00000000000000000000000000000000 00F048F8FFBD10B5041C00F001F80DE0
45c13ae0: 00000000000000000000000000000000 FFB5002001B40F480FA10422FF238133
45c13af0: 00000000000000000000000000000000 00F030F800F032F801B0FFBD0249201C
45c13b00: 00000000000000000000000000000000 00F03CF810BDFFFFA8AFB445D73AC145
45c13b10: 00000000000000000000000000000000 BF3AC145C1050000EF1D0000D98B0F45
45c13b20: 00000000000000000000000000000000 FD880F45D88671455200610064006900
45c13b30: 00000000000000000000000000000000 6F002E00620069006E000000004B1847
45c13b40: 00000000000000000000000000000000 01173845004B184779173845004B1847
45c13b50: 00000000000000000000000000000000 E183E844004D28474D7AE844004D2847
45c13b60: 00000000000000000000000000000000 1990E844004D28472585E844004B1847
45c13b70: 00000000000000000000000000000000 E94E3645004B1847096F2F45004B1847
45c13b80: 000000000000000000000000 C5E12A45004B18479D1A3845
;W580 SW-R8BE001
;Replace the large icons. Mp3 on the cover of the track
;(c) Va_st
;(p) albertnet3
45ad00d0: E9B7EB44 A95CC145
45c15c90: 00000000000000000000000000000000 10B5002105230400002003B401222100
45c15ca0: 00000000000000000000000000000000 00F066F81CBD000070B585B00C000600
45c15cb0: 00000000000000000000000000000000 70680168406800F063F82B4905006846
45c15cc0: 00000000000000000000000000000000 418004AB01AA6946280000F05DF80028
45c15cd0: 00000000000000000000000000000000 40D06846007804283CD2244968460078
45c15ce0: 00000000000000000000000000000000 03280DD801A2125C9744C0460E04080C
45c15cf0: 00000000000000000000000000000000 083102E0103100E0183102A800F04CF8
45c15d00: 00000000000000000000000000000000 7068002102B401684068FF2381330122
45c15d10: 00000000000000000000000000000000 00F046F801B000281CD4049900220120
45c15d20: 00000000000000000000000000000000 00F046F8002812D40198FFF7B1FF019A
45c15d30: 00000000000000000000000000000000 06003100012000F03FF800A8801C01B4
45c15d40: 00000000000000000000000000000000 029903AB0022300000F03AF801B00120
45c15d50: 00000000000000000000000000000000 00F03EF8280000F03FF8684640882080
45c15d60: 00000000000000000000000000000000 002005B070BDC04663EA0000E05DC145
45c15d70: 00000000000000000000000000000000 08B4024B9C4608BC6047C04615A3A944
45c15d80: 00000000000000000000000000000000 004B1847C546234508B4024B9C4608BC
45c15d90: 00000000000000000000000000000000 6047C04671482345004B18474D7D5544
45c15da0: 00000000000000000000000000000000 08B4024B9C4608BC6047C0464D7AE844
45c15db0: 00000000000000000000000000000000 004B18471596E844004B1847A192E844
45c15dc0: 00000000000000000000000000000000 08B4024B9C4608BC6047C04665CCE344
45c15dd0: 00000000000000000000000000000000 004B18471990E844004B184785472345
45c15de0: 00000000000000000000000000000000 6A007000670000006700690066000000
45c15df0: 00000000000000000000000000000000 70006E006700000062006D0070000000
;W580 SW-R8BE001
;Change way of showing Activity Menu
;Now showing Activity Menu like File Manager
;Cambia la manera de mostrar el menu actividad
;Ahora el menu actividad se parece al Adm de Archivos
;(c) jamesbond22
;(p) albertnet3
4538AF10: 09 21
4538A3C6: 09 01
4538C2F6: 09 01
4538CF30: 09 01
4538D7F2: 09 01
4538DAA4: 09 01
4538E16A: 09 01
4538E8F2: 09 01
4538EC8C: 09 01
;W580 SW-R8BE001
;Easy Words Backup
;You can make a backup of your words used on T9 dictionary
;Go to Menu>Messages>Settings>Push>EasyWordsBackup
;Select "Back up to M.S." or "Restore from M.S."
;Backup file saved in "/card/system/PIM"
;You can delete the backup/original file by pressing "C"
;© k790Alex
;(p) anarkes
;Idea by anarkes
;V. 1.3
450F07FE: 02 03
450F0954: 002B02D0012B02D0 004A10473940DD45
450F0A3E: 002802D001284FD094E0 014B1847C0460140DD45
45DD4000: 00000000000000000000000000000000 002807D0012809D002280BD0004B1847
45DD4010: 00000000000000000000000000000000 730B0F45004B1847490A0F45004B1847
45DD4020: 00000000000000000000000000000000 E70A0F4544A000F039F8011C9E4D014B
45DD4030: 00000000000000000000000000000000 1847C046730B0F45002B03D0012B03D0
45DD4040: 00000000000000000000000000000000 0CA102E0034900E00349014A1047C046
45DD4050: 00000000000000000000000000000000 6F0F0F45809BB445749BB44507000000
45DD4060: 00000000000000000000000000000000 AD40DD4508000000AD0B0F4500000000
45DD4070: 00000000000000000000000000000000 000000008040DD45000000005C40DD45
45DD4080: 00000000000000000000000000000000 534D535F55495F45617379576F726473
45DD4090: 00000000000000000000000000000000 4261636B75705F50616765000EB50621
45DD40A0: 00000000000000000000000000000000 3C22014B98470EBD3574344530B50D1C
45DD40B0: 00000000000000000000000000000000 DB2080000C182068002801D000F064F9
45DD40C0: 00000000000000000000000000000000 0021281C00F070F92060022100F070F9
45DD40D0: 00000000000000000000000000000000 19A0FFF7E3FF011C206800F079F91AA1
45DD40E0: 00000000000000000000000000000000 0222206800F04CF90021206800F058F9
45DD40F0: 00000000000000000000000000000000 0121206800F094F9206800F04DF92068
45DD4100: 00000000000000000000000000000000 3F218901144A00F057F920686549134A
45DD4110: 00000000000000000000000000000000 00F052F920680E4923A2013200F04CF9
45DD4120: 00000000000000000000000000000000 20680C490EA2013200F046F920680949
45DD4130: 00000000000000000000000000000000 002200F049F930BD45617379576F7264
45DD4140: 00000000000000000000000000000000 734261636B757000610900007A0A0000
45DD4150: 00000000000000000000000000000000 C20F0000B40F000025090F452D090F45
45DD4160: 00000000000000000000000000000000 F0B5041C734D724E734F081C00F010F9
45DD4170: 00000000000000000000000000000000 00280AD13A1C291C002000F0ECF80028
45DD4180: 00000000000000000000000000000000 0ED0201C00F05CF8F0BD321C291C0020
45DD4190: 00000000000000000000000000000000 00F0E1F8002803D0201C00F04EF8F0BD
45DD41A0: 00000000000000000000000000000000 204800F0CBF8F0BDF0B5041C614D604E
45DD41B0: 00000000000000000000000000000000 614F081C00F0ECF8002816D1321C291C
45DD41C0: 00000000000000000000000000000000 002000F0C8F8002808D13A1C291C0020
45DD41D0: 00000000000000000000000000000000 00F0C1F8002805D112481FE0201C00F0
45DD41E0: 00000000000000000000000000000000 27F8F0BD00F092F817E0321C291C0020
45DD41F0: 00000000000000000000000000000000 00F0B1F8002807D03A1C291C002000F0
45DD4200: 00000000000000000000000000000000 AAF8002802D006E0074807E03A1C291C
45DD4210: 00000000000000000000000000000000 012000F0A0F800F07FF8044800F08EF8
45DD4220: 00000000000000000000000000000000 F0BDC0469F1F00007B0A0000A40B0000
45DD4230: 00000000000000000000000000000000 F0B529A51A4E771C06E0F0B531A501E0
45DD4240: 00000000000000000000000000000000 F0B52AA5184E8E27041C0021201C00F0
45DD4250: 00000000000000000000000000000000 D3F86060391C00F0D3F8311C606800F0
45DD4260: 00000000000000000000000000000000 D7F81249606800F0CFF8606800F094F8
45DD4270: 00000000000000000000000000000000 60680F496A1C00F09FF860680D490EA6
45DD4280: 00000000000000000000000000000000 721C00F099F860683F218901721C00F0
45DD4290: 00000000000000000000000000000000 93F8606803490CA2013200F08DF8F0BD
45DD42A0: 00000000000000000000000000000000 560A0000AF0F0000CD0700001DEE0000
45DD42B0: 00000000000000000000000000000000 C50F0000BE0F000010B5041C606800F0
45DD42C0: 00000000000000000000000000000000 63F8606010BDC04610B5041CFFF7F4FF
45DD42D0: 00000000000000000000000000000000 201C00F0A1F810BD1EB5041C144A1549
45DD42E0: 00000000000000000000000000000000 012000F038F800F011F806E01EB5041C
45DD42F0: 00000000000000000000000000000000 114A1049012000F02EF8201CFFF7DCFF
45DD4300: 00000000000000000000000000000000 1EBDC0461EB5041C094AF2E7FFB50020
45DD4310: 00000000000000000000000000000000 01B40948064A04E0FFB5002001B40448
45DD4320: 00000000000000000000000000000000 054A0449034B00F057F801B0FFBDC046
45DD4330: 00000000000000000000000000000000 58FDB6451458BB452C787145FEB5051C
45DD4340: 00000000000000000000000000000000 0020002103B4291C00220020012300F0
45DD4350: 00000000000000000000000000000000 47F802B0FEBD30B5141C0D1C012809D0
45DD4360: 00000000000000000000000000000000 201C291C002200F043F801D4012030BD
45DD4370: 00000000000000000000000000000000 002030BD201C291C002200F035F830BD
45DD4380: 00000000000000000000000000000000 004B1847A5E53145004B1847294C3645
45DD4390: 00000000000000000000000000000000 004B18475DE43145004B1847994E3645
45DD43A0: 00000000000000000000000000000000 004B184749E43145004B184741E23145
45DD43B0: 00000000000000000000000000000000 004B184771E43145004B184701173845
45DD43C0: 00000000000000000000000000000000 004B184779173845004B1847C9173845
45DD43D0: 00000000000000000000000000000000 004D284759543645004D28472188E844
45DD43E0: 00000000000000000000000000000000 004D28477D982B45004D28472585E844
45DD43F0: 00000000000000000000000000000000 004D2847E183E844004B1847CD563745
45DD4400: 00000000000000000000000000000000 004B1847795A3745004B1847A95A3745
45DD4410: 00000000000000000000000000000000 004B1847895A3745004B184765EA2A45
45DD4420: 0000000000000000 004B1847C9E53145
;W580 SW-R8BE001
;Delete label "Minimize" in Walkman (unnecesary label)
;(c) Laura_P
;(p) M.R.2/mm
44F36DB2: FDF7ABFD C046C046
;W580 SW-R8BE001
;ClearBass Equalizer add-on
;(!) For new version 2.0
;Sending event 0x3020 when pressing 'Equalizer' in music application
;(c) mc_kibel
;(p) juLi0Naru
44F3C488: F1B53A4E0C1C0D1C3049A435301C5030 024800B570F320FD00BDFFFF20300000
;W580 SW-R8BE001
;FeedbackTicker Mod
;FeedbackTicker modo
;(c) Therion
;(p) Heber?????®
;ver. 2
452b8a24: 00 02 ;Scrolling ;Desplazamiento
452bade2: 14D1 C046
452badea: 10D1 C046
452badf8: 09D1 C046
452bc908: 2030 1830
452badfa: 00213520 01212820
4531126a: FF210906 80210906
452bb0e8: A8800020E880AA88 004B1847D146DD45
45dd46d0: 00000000000000000000000000000000 A8800020E880AA886988201C084B9847
45dd46e0: 00000000000000000000000000000000 00220021201C094B98470121201C094B
45dd46f0: 00000000000000000000000000000000 98470549201C034B9847054B1847FFFF
45dd4700: 00000000000000000000000000000000 7DC0354575CF354500100260DDC03545
45dd4710: 0000000000000000 F9B02B4529CA3545
;Scrolling mode ;Desplazamiento
;01 - Left to right ;Izquierda a derecha
;02 - Right to left ;Derecha a izquierda
;W580 SW-R8BE001
;Ability to run Deskbar elf's Gui by menu.ml (event 0x3010)
;In menu.ml required MenuItem_EditDeskbar
;Works only with Deskbar 3.12 or later
;Habilidad de correr el elf Deskbar Gui por el menu.ml (event 0x3010)
;En el menu.ml nesesitan: MenuItem_EditDeskbar
;Funciona unicamente con Deskbar 3.12 o mas tarde
;(c) mc_kibel
;(p) DaRkMaN
45BCCF98: A4B1BC453DCD2C45 4447DD452147DD45
45DD4720: 00000000000000000000000000000000 10B5041C00F02CF8002802D001281ED0
45DD4730: 00000000000000000000000000000000 10BD201C002802D0014800F029F810BD
45DD4740: 00000000000000000000000000000000 103000004D0065006E00750049007400
45DD4750: 00000000000000000000000000000000 65006D005F0045006400690074004400
45DD4760: 00000000000000000000000000000000 650073006B0062006100720000000348
45DD4770: 00000000000000000000000000000000 011C201C00F008F810BDFFFF00230000
45DD4780: 00000000000000000000000000000000 004B18473D523845004B1847D9513845
45DD4790: 0000000000000000 004B1847D1CE2A45
;W580 SW-R8BE001
;Select item with numeric keys in USB Connection Menu
;Seleccione el item con las teclas numéricas en el Menu de Conexion USB
;1=File transfer/Transf. archivo
;2=Phone mode/Modo telefono
;3=Print/Imprimir
;© K790alex
;(p) Darkman
45215DA8: 2649206A 26498847
45215E44: 5D5C2145 A147DD45
45DD47A0: 00000000000000000000000000000000 206A03490FB50121206A024B98470FBD
45DD47B0: 0000000000000000 5D5C2145C9E53145
;W580_R8BE001
;Turn On/Off Bluetooth
;Keep holding activity key
;(!) Work in all books
;© k790Alex
;(p) 05M4N
452ADEC6: 1F2C1CD0202C16D0212C16D0 014B1847C046C147DD45C046
45DD47C0: 00000000000000000000000000000000 1F2C05D0202C07D0212C07D0054B1847
45DD47D0: 00000000000000000000000000000000 054800F005F838BD044B1847044B1847
45DD47E0: 00000000000000000000000000000000 044B1847D3DE2A45F4ACA945FDDE2A45
45DD47F0: 0000000000000000 01DF2A4519F03845
;W580 SW-R8BE001
;Keys work in message "Phone ready to be used with computer"
;Back=Return to menu
;LongBack=Close menu and return to standby
;Left Softkey=Close
;(c) k790alex
;(p) anarkes
45215F36: 0949206A 09498847
45215F5C: B80B0000 C147DD45
45DD47C0: 00000000000000000000000000000000 206A1D490FB5206A0B490C4A0C4B9847
45DD47D0: 00000000000000000000000000000000 206A0949154A0B4B9847206A3F218901
45DD47E0: 00000000000000000000000000000000 0AA20132074B9847206A07490BA20132
45DD47F0: 00000000000000000000000000000000 044B98470FBDC046BF0F000083030000
45DD4800: 00000000000000000000000000000000 7917384501173845AF0F000000B50149
45DD4810: 00000000000000000000000000000000 014A10479055B7456F0F0F4500B50349
45DD4820: 00000000000000000000000000000000 884703480349884700BDC04665EA2A45
45DD4830: 000000000000000000000000 48080000D1CE2A4588130000
;W580 SW-R8BE001
;Add icons to navigation keys in "Shortcuts (Links)" menu
;Updated GUI
;© Therion
;(p) anarkes
4534A348: 0698211C8FF766FB7060 004B984771E8B145C046
45B1E870: 00000000000000000000000000000000 0698211C2C4B9847706002212B4B9847
45B1E880: 00000000000000000000000000000000 26497068264B984704217068254B9847
45B1E890: 00000000000000000000000000000000 02217068264B98471E497068271C1E4B
45B1E8A0: 00000000000000000000000000000000 98472C482C490090684641600C398160
45B1E8B0: 00000000000000000000000000000000 091DC160706804226946254B98471D48
45B1E8C0: 00000000000000000000000000000000 204A01B470680023191C00F01BF81A48
45B1E8D0: 00000000000000000000000000000000 1C4A01B470680023012100F013F81748
45B1E8E0: 00000000000000000000000000000000 184A01B470680023022100F00BF81448
45B1E8F0: 00000000000000000000000000000000 144A01B470680023032100F003F804B0
45B1E900: 00000000000000000000000000000000 114B984708B4114B9C4608BC6047FFFF
45B1E910: 00000000000000000000000000000000 63A33445F7180000A50432450CEC0000
45B1E920: 00000000000000000000000000000000 DD043245790032451D9A2D45899C2D45
45B1E930: 00000000000000000000000000000000 8904324534EE000033EE000031EE0000
45B1E940: 00000000000000000000000000000000 32EE0000FFFF00007FA33445119F2D45
45B1E950: 000000000000000000000000 699D2D450619000002190000
;W580 SW-R8BE001
;File Manager Shortcuts
;Add ability to set Shortcuts from 35 softkeys in File Manager on keys (1,..,#) Short/Long press
;Add 3 options in File Manager-> More: Shortcuts(On/Off,Edit),Minimize,Close
;in Shortcuts edit(Access Keys page):
;-Select softkeys to set shortcuts on keys
;-Press keys(1,..,#) for cursor to keys items
;-Press joystick left/right for toggle short/long press mode
;(!) Rollback "Disable search on File Manager by pressing the number keys" patch
;Fixed bugs
;v 1.1
;© Amir_82111
;(p) anarkes
44EC0242: 201C03F000F800280AD0 01480047FFFF3309CF45
44EC00CA: 287A00280ED10221381C 01480047FFFF0109CF45
45CF0900: 00000000000000000000000000000000 00F010F8002809D1287A002806D10221
45CF0910: 00000000000000000000000000000000 381C014B1847FFFFD500EC4400490847
45CF0920: 00000000000000000000000000000000 EF00EC44FEB500221821002000F067FD
45CF0930: 00000000000000000000000000000000 FEBD381C00F00EF8201C00F009FE0028
45CF0940: 00000000000000000000000000000000 04D001480047FFFF4D02EC4400490847
45CF0950: 00000000000000000000000000000000 6302EC44FFB5041C87B0022000226946
45CF0960: 00000000000000000000000000000000 00F04DFD6E46201C00F05AFE071C00F0
45CF0970: 00000000000000000000000000000000 5FFE051C381C00F057FE0121002803D0
45CF0980: 00000000000000000000000000000000 0221A84200D00021717600223021201C
45CF0990: 00000000000000000000000000000000 00F0C2FD5C4A12683021201C00F0C8FD
45CF09A0: 00000000000000000000000000000000 504A307E002800D04F4A3121201C00F0
45CF09B0: 00000000000000000000000000000000 B3FD504A307E002801D04F4A12683121
45CF09C0: 00000000000000000000000000000000 201C00F0B5FD30213122201C00F018FE
45CF09D0: 00000000000000000000000000000000 434A3221201C00F09FFD484A12683221
45CF09E0: 00000000000000000000000000000000 201C00F0A5FD30213222201C00F008FE
45CF09F0: 00000000000000000000000000000000 3E4A201C332100F08FFD3D4A201C3421
45CF0A00: 00000000000000000000000000000000 00F08AFDDF480078002805D03C4A1268
45CF0A10: 00000000000000000000000000000000 201C332100F08CFDDA484078002805D0
45CF0A20: 00000000000000000000000000000000 384A1268201C342100F082FD307E0028
45CF0A30: 00000000000000000000000000000000 54D00027381C315C707E022804D11029
45CF0A40: 00000000000000000000000000000000 1ED011291CD00DE000280BD00E2909D0
45CF0A50: 00000000000000000000000000000000 0F2907D0132913DB1B2903DB1E2901D0
45CF0A60: 00000000000000000000000000000000 20290DDB29A2515C14203A181E2A00D1
45CF0A70: 00000000000000000000000000000000 13221F2A00D11E220323201C00F050FD
45CF0A80: 00000000000000000000000000000000 01370C2FD6D10027381C0C30315C707E
45CF0A90: 00000000000000000000000000000000 022804D110291ED011291CD00DE00028
45CF0AA0: 00000000000000000000000000000000 0BD00E2909D00F2907D0132913DB1B29
45CF0AB0: 00000000000000000000000000000000 03DB1E2901D020290DDB14A2515C1420
45CF0AC0: 00000000000000000000000000000000 3A181E2A00D113221F2A00D11E220123
45CF0AD0: 00000000000000000000000000000000 201C00F025FD01370C2FD5D107B0FFBD
45CF0AE0: 00000000000000000000000000000000 BD11CF456F11CF458711CF45AF11CF45
45CF0AF0: 00000000000000000000000000000000 6312CF45C3010000080ECF450C0ECF45
45CF0B00: 00000000000000000000000000000000 100ECF45140ECF457C0DCF45CC111213
45CF0B10: 00000000000000000000000000000000 151618191A1B180B0C0D4E5C62636E6F
45CF0B20: 00000000000000000000000000000000 707475797A7B7C050607861E31323334
45CF0B30: 00000000000000000000000000000000 F0B5041C924E0027321C391C7031201C
45CF0B40: 00000000000000000000000000000000 00F0EAFC90A2042078431258391C7031
45CF0B50: 00000000000000000000000000000000 201C00F0EDFC391C7031201C00F0D5F9
45CF0B60: 00000000000000000000000000000000 012F0DD100226021201C00F0D5FCAA4A
45CF0B70: 00000000000000000000000000000000 6021201C00F0DCFC6021201C00F0C5F9
45CF0B80: 00000000000000000000000000000000 032F07DA012F05DB60213A1C7032201C
45CF0B90: 00000000000000000000000000000000 00F036FD032F0DD100226121201C00F0
45CF0BA0: 00000000000000000000000000000000 BBFC9F4A6121201C00F0C2FC6121201C
45CF0BB0: 00000000000000000000000000000000 00F0ABF90B2F07DA032F05DB61213A1C
45CF0BC0: 00000000000000000000000000000000 7032201C00F01CFD0B2F0DD100226221
45CF0BD0: 00000000000000000000000000000000 201C00F0A1FC914A6221201C00F0A8FC
45CF0BE0: 00000000000000000000000000000000 6221201C00F091F90E2F07DA0B2F05DB
45CF0BF0: 00000000000000000000000000000000 62213A1C7032201C00F002FD102F0FD1
45CF0C00: 00000000000000000000000000000000 00226321201C00F087FC864A6321201C
45CF0C10: 00000000000000000000000000000000 00F08EFC6321201C00F077F900E08BE7
45CF0C20: 00000000000000000000000000000000 122F07DA102F05DB63213A1C7032201C
45CF0C30: 00000000000000000000000000000000 00F0E6FC122F0DD100226421201C00F0
45CF0C40: 00000000000000000000000000000000 6BFC794A6421201C00F072FC6421201C
45CF0C50: 00000000000000000000000000000000 00F05BF9172F07DA122F05DB64213A1C
45CF0C60: 00000000000000000000000000000000 7032201C00F0CCFC172F0DD100226521
45CF0C70: 00000000000000000000000000000000 201C00F051FC6D4A6521201C00F058FC
45CF0C80: 00000000000000000000000000000000 6521201C00F041F91B2F07DA172F05DB
45CF0C90: 00000000000000000000000000000000 65213A1C7032201C00F0B2FC202F0DD1
45CF0CA0: 00000000000000000000000000000000 00226621201C00F037FC344A6621201C
45CF0CB0: 00000000000000000000000000000000 00F03EFC6621201C00F027F9222F07DA
45CF0CC0: 00000000000000000000000000000000 202F05DB66213A1C7032201C00F098FC
45CF0CD0: 00000000000000000000000000000000 0137242FA3D1F0BDF0B5041C0D1C87B0
45CF0CE0: 00000000000000000000000000000000 02200022694600F08AFB6E4600210023
45CF0CF0: 00000000000000000000000000000000 002D00D00C23CA18B05800280DD10431
45CF0D00: 00000000000000000000000000000000 0C29F8D13460F74870601F48B0606846
45CF0D10: 00000000000000000000000000000000 0322052100F0F8FB041C201C07B0F0BD
45CF0D20: 00000000000000000000000000000000 F0B5071C0C1C84B06E460025F3A04019
45CF0D30: 00000000000000000000000000000000 0122062100F0E8FB3060EB487060E948
45CF0D40: 00000000000000000000000000000000 B0603020385C291C002800D00C310022
45CF0D50: 00000000000000000000000000000000 002000F054FB0CA1042250430858F060
45CF0D60: 00000000000000000000000000000000 68460422052100F0CFFB042169436050
45CF0D70: 00000000000000000000000000000000 01350C2DDAD104B0F0BDFFFFFC180000
45CF0D80: 00000000000000000000000000000000 3511CF456816CF450019000097050000
45CF0D90: 00000000000000000000000000000000 9B050000AA050000A8050000C5050000
45CF0DA0: 00000000000000000000000000000000 4E040000A6050000A4050000AB050000
45CF0DB0: 00000000000000000000000000000000 7D04000087040000010500005C050000
45CF0DC0: 00000000000000000000000000000000 8304000011050000E2040000DE040000
45CF0DD0: 00000000000000000000000000000000 D9050000B4040000D6050000D7050000
45CF0DE0: 00000000000000000000000000000000 D90400006E0400006D04000071040000
45CF0DF0: 00000000000000000000000000000000 6F040000860200008B0200000F0F0000
45CF0E00: 00000000000000000000000000000000 F0040000CE040000C101000001070000
45CF0E10: 00000000000000000000000000000000 1A06000075030000A1050000DC040000
45CF0E20: 00000000000000000000000000000000 EB050000E3040000FE050000B7050000
45CF0E30: 00000000000000000000000000000000 F0B50F1C0021381C00F096FB041C3820
45CF0E40: 00000000000000000000000000000000 3C5082B06E463DA006210A2200F05CFB
45CF0E50: 00000000000000000000000000000000 011C201C00F090FB0221201C00F0B8FB
45CF0E60: 00000000000000000000000000000000 3220395C201C00F08BFB37A005220621
45CF0E70: 00000000000000000000000000000000 00F04AFB0021FFF72FFF306034A00422
45CF0E80: 00000000000000000000000000000000 062100F041FB0121FFF726FF70600222
45CF0E90: 00000000000000000000000000000000 6946201C00F050FB0121201C00F09CFB
45CF0EA0: 00000000000000000000000000000000 8E4A3F218901201C00F036FB8B4A8649
45CF0EB0: 00000000000000000000000000000000 201C00F031FB204A8449201C00F02CFB
45CF0EC0: 00000000000000000000000000000000 1B4A3521201C00F027FB184A3521201C
45CF0ED0: 00000000000000000000000000000000 00F02EFB174A7E49201C00F01DFB201C
45CF0EE0: 00000000000000000000000000000000 00F046FB02B0F0BDF0B51BA006212922
45CF0EF0: 00000000000000000000000000000000 00F00AFB011C00250B4C30B40A480123
45CF0F00: 00000000000000000000000000000000 002200F071FB02B0F0BDF0B5041C0E1C
45CF0F10: 00000000000000000000000000000000 1CA00621962200F0F7FA021C311C201C
45CF0F20: 00000000000000000000000000000000 00F072FBF0BDFFFFFFFFFF6FC90C0000
45CF0F30: 00000000000000000000000000000000 E90ECF450B12CF458313CF4550726573
45CF0F40: 00000000000000000000000000000000 73204D6F646500FF53686F727400FFFF
45CF0F50: 00000000000000000000000000000000 4C6F6E6700FFFFFF46696C65204D616E
45CF0F60: 00000000000000000000000000000000 616765722053686F7274637574732076
45CF0F70: 00000000000000000000000000000000 312E310A0AA920416D69725F38323131
45CF0F80: 00000000000000000000000000000000 3100FFFF2D53656C65637420736F6674
45CF0F90: 00000000000000000000000000000000 6B65797320666F72207365742073686F
45CF0FA0: 00000000000000000000000000000000 727463757473206F6E206B6579732E0A
45CF0FB0: 00000000000000000000000000000000 2D5072657373206B65797328312C2E2E
45CF0FC0: 00000000000000000000000000000000 2C232920666F7220637572736F722074
45CF0FD0: 00000000000000000000000000000000 6F206B657973206974656D732E0A2D50
45CF0FE0: 00000000000000000000000000000000 72657373206A6F79737469636B206C65
45CF0FF0: 00000000000000000000000000000000 66742F726967687420666F7220746F67
45CF1000: 00000000000000000000000000000000 676C652073686F72742F6C6F6E672070
45CF1010: 00000000000000000000000000000000 72657373206D6F64652E00FFF0B5071C
45CF1020: 00000000000000000000000000000000 002100F0A1FA041C3021795C37A00029
45CF1030: 00000000000000000000000000000000 00D03BA01122062100F066FA011C201C
45CF1040: 00000000000000000000000000000000 00F09AFA0C21201C00F0C2FA3120395C
45CF1050: 00000000000000000000000000000000 201C00F095FA8CB06946381CFFF760FE
45CF1060: 00000000000000000000000000000000 69460C22201C00F067FA8C49201C00F0
45CF1070: 00000000000000000000000000000000 99F91B4A3F218901201C00F04DFA174A
45CF1080: 00000000000000000000000000000000 1149201C00F048FA134A1049201C00F0
45CF1090: 00000000000000000000000000000000 43FA104A0D49201C00F04AFA00230522
45CF10A0: 00000000000000000000000000000000 0A49201C00F03CFA201CFFF741FD0F48
45CF10B0: 00000000000000000000000000000000 8078002803D00121201C00F0A9FA201C
45CF10C0: 00000000000000000000000000000000 00F056FA0CB0F0BDAF0F0000C20F0000
45CF10D0: 00000000000000000000000000000000 B40F0000810900005113CF456D12CF45
45CF10E0: 00000000000000000000000000000000 4512CF45200000783A0000786816CF45
45CF10F0: 00000000000000000000000000000000 536F66746B65797300FFFFFF31323334
45CF1100: 00000000000000000000000000000000 35363738392A302300FFFFFF41636365
45CF1110: 00000000000000000000000000000000 7373204B6579732D53686F727400FFFF
45CF1120: 00000000000000000000000000000000 416363657373204B6579732D4C6F6E67
45CF1130: 00000000000000000000000000000000 00FFFFFFF0B5071C0C1C00F06DFA061C
45CF1140: 00000000000000000000000000000000 703E201C00F04CFA011C312039543020
45CF1150: 00000000000000000000000000000000 385C002800D00C31321C012000F04FF9
45CF1160: 00000000000000000000000000000000 201C00F0FDF9381CFFF758FFF0BDF0B5
45CF1170: 00000000000000000000000000000000 071C0C1C01221821012000F040F9381C
45CF1180: 00000000000000000000000000000000 00F00DF8F0BDF0B5071C0C1C00221821
45CF1190: 00000000000000000000000000000000 012000F034F9381C00F001F8F0BDF0B5
45CF11A0: 00000000000000000000000000000000 00F0F6F9011C3E4800F0F6F9F0BDF0B5
45CF11B0: 00000000000000000000000000000000 00F0FEF9002100F0FFF9F0BDF0B5061C
45CF11C0: 00000000000000000000000000000000 354800F0EDF9002803D0002100F0ECF9
45CF11D0: 00000000000000000000000000000000 19E0052301224021002000F0B1F9071C
45CF11E0: 00000000000000000000000000000000 0021002003B442A300222E49381C00F0
45CF11F0: 00000000000000000000000000000000 E7F902B034203E50002030217850381C
45CF1200: 00000000000000000000000000000000 29A100F0F9F90020F0BDF0B5071C0C1C
45CF1210: 00000000000000000000000000000000 201C00F0E5F9051C32203D540026002D
45CF1220: 00000000000000000000000000000000 00D00C25A9190022012000F0E8F80136
45CF1230: 00000000000000000000000000000000 0C2EF7D1201C00F093F9381C1AA100F0
45CF1240: 00000000000000000000000000000000 DBF9F0BDF0B5071C081C00F089F93821
45CF1250: 00000000000000000000000000000000 785800F085F9381C13A100F0CDF9F0BD
45CF1260: 00000000000000000000000000000000 7047F0B500F078F9F0BD081CF0B5071C
45CF1270: 00000000000000000000000000000000 34217858FFF793FF381C00F06DF9F0BD
45CF1280: 00000000000000000000000000000000 1BA100B50068406800F07EF901210028
45CF1290: 00000000000000000000000000000000 00D00021081C00BD8112CF450D13CF45
45CF12A0: 00000000000000000000000000000000 EC1300006112CF45CC12CF4500000000
45CF12B0: 00000000000000000000000000000000 B412CF4507000000310ECF4548080000
45CF12C0: 00000000000000000000000000000000 6B12CF45000000000000000046696C65
45CF12D0: 00000000000000000000000000000000 4D616E6167657253686F727463757473
45CF12E0: 00000000000000000000000000000000 426F6F6B5F456469745F7061676500FF
45CF12F0: 00000000000000000000000000000000 46696C654D616E6167657253686F7274
45CF1300: 00000000000000000000000000000000 63757473426F6F6B00FFFFFFF0B5071C
45CF1310: 00000000000000000000000000000000 0C1C00F081F9011C50390C2903D0201C
45CF1320: 00000000000000000000000000000000 00F02EF913E0201C00F05AF931217854
45CF1330: 00000000000000000000000000000000 3021785C0122002800D000227A543220
45CF1340: 00000000000000000000000000000000 3A54201C00F00CF9381CFFF767FEF0BD
45CF1350: 00000000000000000000000000000000 F0B5071C0C1C201C00F042F9011C3120
45CF1360: 00000000000000000000000000000000 39543020385C002800D00C3100220120
45CF1370: 00000000000000000000000000000000 00F045F8201C00F0F3F8381CFFF74EFE
45CF1380: 00000000000000000000000000000000 F0BDF0B5071C0C1C201C00F029F93021
45CF1390: 00000000000000000000000000000000 785432217854002031217854381CFFF7
45CF13A0: 00000000000000000000000000000000 3DFEF0BDF0B5041C0E1C0027391C5031
45CF13B0: 00000000000000000000000000000000 321C201C00F0B0F8391C503114203A18
45CF13C0: 00000000000000000000000000000000 1E2A00D113221F2A00D11E220023201C
45CF13D0: 00000000000000000000000000000000 00F0A6F801370C2FE8D15C21321C201C
45CF13E0: 00000000000000000000000000000000 00F09AF800230B225C21201C00F098F8
45CF13F0: 00000000000000000000000000000000 00230F225C21201C00F092F8F0BDFEB5
45CF1400: 00000000000000000000000000000000 071C0E1C151C87B0022F04D1341C0021
45CF1410: 00000000000000000000000000000000 0022002602E06C46391C321C2B1C201C
45CF1420: 00000000000000000000000000000000 00F003F8A05D07B0FEBDFEB5071C0E1C
45CF1430: 00000000000000000000000000000000 151C00210020785004311C29FBD181B0
45CF1440: 00000000000000000000000000000000 6A461370557018A022A1002200F0F4F8
45CF1450: 00000000000000000000000000000000 04D4012204E00226022201E003260222
45CF1460: 00000000000000000000000000000000 002001B410A01BA1FF23813300F0E8F8
45CF1470: 00000000000000000000000000000000 041C01B0032E0BD0022E05D0391C201C
45CF1480: 00000000000000000000000000000000 192200F0E5F808E06A46107851787854
45CF1490: 00000000000000000000000000000000 1922391C201C00F0DFF8201C00F0E0F8
45CF14A0: 00000000000000000000000000000000 012ED8D001B0FEBD2F00740070006100
45CF14B0: 00000000000000000000000000000000 2F00730079007300740065006D002F00
45CF14C0: 00000000000000000000000000000000 730065007400740069006E0067007300
45CF14D0: 00000000000000000000000000000000 0000FFFF460069006C0065004D006100
45CF14E0: 00000000000000000000000000000000 6E0061006700650072005F0053006800
45CF14F0: 00000000000000000000000000000000 6F007200740063007500740073002E00
45CF1500: 00000000000000000000000000000000 620069006E00000008B4024B9C4608BC
45CF1510: 00000000000000000000000000000000 6047FFFF35743445004B184701173845
45CF1520: 00000000000000000000000000000000 08B4024B9C4608BC6047FFFFC5183845
45CF1530: 00000000000000000000000000000000 004B184779173845004B1847A5E53145
45CF1540: 00000000000000000000000000000000 08B4024B9C4608BC6047FFFF51DCEB44
45CF1550: 00000000000000000000000000000000 004B18474932EC44004B184765EA2A45
45CF1560: 00000000000000000000000000000000 004B1847294C3645004B184741E23145
45CF1570: 00000000000000000000000000000000 004B1847994E3645004B1847C9533645
45CF1580: 00000000000000000000000000000000 004B184749E43145004B184725745544
45CF1590: 00000000000000000000000000000000 004B184725EB2A45004B184729CF2A45
45CF15A0: 00000000000000000000000000000000 004B184799DC2A45004B18472DE72A45
45CF15B0: 00000000000000000000000000000000 004B1847D9192C45004B1847F5E62A45
45CF15C0: 00000000000000000000000000000000 08B4024B9C4608BC6047FFFF49E42A45
45CF15D0: 00000000000000000000000000000000 004B184771E43145004B1847C9E53145
45CF15E0: 00000000000000000000000000000000 004B18475DE4314508B4024B9C4608BC
45CF15F0: 00000000000000000000000000000000 6047FFFF7D982B45004B1847C5E12A45
45CF1600: 00000000000000000000000000000000 004B184759183845004B184765173845
45CF1610: 00000000000000000000000000000000 004B1847A5193845004B184731E03745
45CF1620: 00000000000000000000000000000000 004B1847AD4C3645004B18473528EC44
45CF1630: 00000000000000000000000000000000 004B18474928EC44004B1847E183E844
45CF1640: 00000000000000000000000000000000 08B4024B9C4608BC6047FFFF4D7AE844
45CF1650: 00000000000000000000000000000000 004B1847A192E844004B18476D94E844
45CF1660: 0000000000000000 004B18471990E844
45CF1668: 00 01; Show Minimize lable in softkeys (01 yes 00 no)
45CF1669: 00 01; Show Close lable in softkeys (01 yes 00 no)
45CF166A: 00 01; Swap softkeys in Shortcuts edit (Access Keys page) (01 yes 00 no)
;W580 SW-R8BE001
;Change GUI of SMS editor
;Added animation when window appears
;(c) Therion
;(p) c368511
450E66D8: 0121 0C21
452E8124: 1A21 3821
452EDA68: 0621 0E21
452F52C0: 012122208FF0CCF8 004B98474117CF45
452ED898: FF210906201CFFF77BFF 004B98474D17CF45C046
452F1CF8: 2868164968F01EF88220 004B98475917CF45C046
45CF1740: 00000000000000000000000000000000 2421201C0A4B98470D4B98470E49201C
45CF1750: 00000000000000000000000000000000 0C4B98470D4B98470D4928680D4B9847
45CF1760: 00000000000000000000000000000000 06492868034B9847412000010A4B9847
45CF1770: 00000000000000000000000000000000 9DCA354575CF35453011020000015000
45CF1780: 00000000000000000000000000000000 D1522F4599D72E45CC0000FFABD82E45
45CF1790: 000000000000000000000000 110900003D9D3545051D2F45
;W580 SW-R8BE001
;Change GUI of call status
;(!) Edit your CallStatusInfo.xml
;© Therion
;(p)c368511
44DAD902: 061C 2426
44DAD8C2: 80214900 2421FFE7
44DADE98: 6EF30000 FFFFFFFF
452C1BA8: 6EF30000 FFFFFFFF
44DAD92C: 011C201CA2F15CFE0122 004B9847E118CF45C046
45CF18E0: 00000000000000000000000000000000 01223521201C0A4B9847011C201C074B
45CF18F0: 00000000000000000000000000000000 98470349201C034B9847034B9847FFFF
45CF1900: 00000000000000000000000000000000 111111A0C1CE354547D9DA4471CE3545
45CF1910: 0000000000000000 6D44384561443845
;W580 SW-R8BE001
;BlackBerry List Menu (BBLM)
;Change mode when entering Quick Acces Menu (QAM)
;Now entering BBLM
;Items:
;Browser - Messages - Main display - Calls - Now playing
;(!) Enter again to QAM pressing On/Off key
;© k790Alex
;(p) anarkes
;V1.0 Beta Test
45BB14F0: 15C52D45 1920DD45
45BB14F8: E5C42D45 15C52D45
45DD1FA0: 00000000000000000000000000000000 004B184741E23145004B184771E43145
45DD1FB0: 00000000000000000000000000000000 004B1847ADE43145004B184749E43145
45DD1FC0: 00000000000000000000000000000000 004B18479DE53145004B184701173845
45DD1FD0: 00000000000000000000000000000000 004B1847994E3645004B184799EF3145
45DD1FE0: 00000000000000000000000000000000 004B1847A5EF3145004B18475DE43145
45DD1FF0: 00000000000000000000000000000000 004B1847816F3845004B1847D1CE2A45
45DD2000: 00000000000000000000000000000000 004B18471DF03145004B1847294C3645
45DD2010: 00000000000000000000000000000000 004B184789EB2A4530B50C1CA0690028
45DD2020: 00000000000000000000000000000000 01D0FFF7F1FF0021201CFFF7B9FFA061
45DD2030: 00000000000000000000000000000000 0421FFF7BDFF0021201CFFF7E9FF0521
45DD2040: 00000000000000000000000000000000 A069FFF7B1FF0121A069FFF7B5FF10A1
45DD2050: 00000000000000000000000000000000 0131A069FFF7B4FFA069FFF7B9FFA069
45DD2060: 00000000000000000000000000000000 3F218901364AFFF7AFFFA0690549344A
45DD2070: 00000000000000000000000000000000 FFF7AAFFA069044921A20132FFF7A4FF
45DD2080: 00000000000000000000000000000000 30BDC046AF0F0000C20F0000B40F0000
45DD2090: 00000000000000000000000000000000 70B5041CFFF7A0FF002808D0012809D0
45DD20A0: 00000000000000000000000000000000 02280AD003280BD00B4D0C4E0AE00C4D
45DD20B0: 00000000000000000000000000000000 0C4E07E00C4D0D4E04E00D4D0D4E01E0
45DD20C0: 00000000000000000000000000000000 0D4D0E4E291C201CFFF78AFF321C0021
45DD20D0: 00000000000000000000000000000000 201CFFF795FF70BD8C100000F1EA0000
45DD20E0: 00000000000000000000000000000000 24180000B2F300003A1100008BEC0000
45DD20F0: 00000000000000000000000000000000 2319000031F30000E10F0000EDE50000
45DD2100: 00000000000000000000000000000000 10B5041C081CFFF76FFF00280BD00128
45DD2110: 00000000000000000000000000000000 0BD002280BD003280BD004280CD14720
45DD2120: 00000000000000000000000000000000 FFF76AFF08E0074804E0074802E00748
45DD2130: 00000000000000000000000000000000 F6E70748FFF75CFF201C014CA04710BD
45DD2140: 00000000000000000000000000000000 65EA2A452084BA4560E0B14548080000
45DD2150: 00000000 F0A6BC45
;W580 SW-R8BE001
;Add softkey, which allows you to pause music playback in the file manager
;V2.0
;Added softkey that lets you open the current track MusicTagger.elf (to stop music now completely press back button or the joystick)
;The path to the elf "/ tpa / user / other / ZBin / MusicTagger.elf"
;Anadir Softkey para pausar la musica en el administrador de archivos
;V2.0
;Anadida softkey que le permite abrir la pista actual en MusicTagger.elf
;(para detener musica por completo ahora con tecla atras o dejando presionado el joystick)
;Ruta del elf "/tpa/user/other/ZBin/MusicTagger.elf"
;(!) Softkey hook
;(C) MaPkiZzz aKa Vital
;(e) yener90 (fixed bug)
;(P) Heber?????®
44f37abc: 0221 391C
44f37ab6: 05D0 2847
44f37ae0: FCF714FF C046C046
44f37b3c: 4D7BF344 D1E5BF45
44f37436: AD218900 81218900
44F37442: 9E48 4EE0
44F374E8: 7448 FBE7
45bfe5d0: 00000000000000000000000000000000 2C4A0F21E06900F045F8264A0F21E069
45bfe5e0: 00000000000000000000000000000000 00F042F8284A2249E06900F03BF8234A
45bfe5f0: 00000000000000000000000000000000 1F49E06900F038F8244D1C4F244B9847
45bfe600: 00000000000000000000000000000000 10B5041C00F02CF81D4AE0690F2100F0
45bfe610: 00000000000000000000000000000000 29F8194A00E0001CE0690F2100F024F8
45bfe620: 00000000000000000000000000000000 10BD10B5041C00F019F8164AE0690F21
45bfe630: 00000000000000000000000000000000 00F018F80F4AEFE7002010BD00402DE9
45bfe640: 00000000000000000000000000000000 741090E50030A0E3082091E5041091E5
45bfe650: 00000000000000000000000000000000 4C008FE20D0100EF0080BDE80D4B1847
45bfe660: 00000000000000000000000000000000 0D4B18470D4B18470D4B1847FE0F0000
45bfe670: 00000000000000000000000000000000 C20F0000B40500004305000001070000
45bfe680: 00000000000000000000000000000000 23E6BF4501E6BF453CE6BF454D7BF344
45bfe690: 00000000000000000000000000000000 B97AF344CD73F344CD76F344D948F344
45bfe6a0: 00000000000000000000000000000000 0D49F3442F007400700061002F007500
45bfe6b0: 00000000000000000000000000000000 7300650072002F006F00740068006500
45bfe6c0: 00000000000000000000000000000000 72002F005A00420069006E002F004D00
45bfe6d0: 00000000000000000000000000000000 75007300690063005400610067006700
45bfe6e0: 0000000000000000000000000000 650072002E0065006C0066000000
;W580 SW-R8BE001
;Flash THM
;Install Flash Menu along with theme
;Flash Menu file should be packed in .thm theme
;Supported installation of the Flash Menu in the old way - .swf in FS
;(!) The patch is only for the W-series on db2020
;v.1.9 fix
;© KrasH
;(p) c368511
453830E2: 2078012808D18D4A211C 01480047FFFF1116C245
45C21610: 00000000000000000000000000000000 2078012832D1C0B4211C10310C9800F0
45C21620: 00000000000000000000000000000000 8BF8071C00F073F8061C002102B4231C
45C21630: 00000000000000000000000000000000 10333A1C311C0D9800F08AF801B00128
45C21640: 00000000000000000000000000000000 10D000F023F8002001B426A3244A211C
45C21650: 00000000000000000000000000000000 1031234800F090F801B022A1204800F0
45C21660: 00000000000000000000000000000000 75F805E000F012F8391C301C00F01DF8
45C21670: 00000000000000000000000000000000 301C00F058F8C0BC0248004700F006F8
45C21680: 00000000000000000000000000000000 0148004707313845FB30384500B50022
45C21690: 00000000000000000000000000000000 14A1134800F056F8002800D504E00022
45C216A0: 00000000000000000000000000000000 10A10F4800F050F800BD83B5002001B4
45C216B0: 00000000000000000000000000000000 FF23813304220BA1094800F04EF801B0
45C216C0: 00000000000000000000000000000000 071C00280AD4019A009900F037F8381C
45C216D0: 00000000000000000000000000000000 00F036F803A1024800F038F883BDFFFF
45C216E0: 00000000000000000000000000000000 4CA1714546006C006100730068005F00
45C216F0: 00000000000000000000000000000000 4D0065006E0075005F00540068006500
45C21700: 00000000000000000000000000000000 6D0065002E00730077006600000001B5
45C21710: 00000000000000000000000000000000 0021C84303B4052301220299002000F0
45C21720: 00000000000000000000000000000000 21F803B000BD00B500230022011C0020
45C21730: 00000000000000000000000000000000 00F01DF800BDFFFF124B1847124B1847
45C21740: 00000000000000000000000000000000 124B1847124B1847124B1847124B1847
45C21750: 00000000000000000000000000000000 08B4124B9C4608BC604708B4104B9C46
45C21760: 00000000000000000000000000000000 08BC604708B40F4B9C4608BC604708B4
45C21770: 00000000000000000000000000000000 0D4B9C4608BC604708B40C4B9C4608BC
45C21780: 00000000000000000000000000000000 6047FFFF51A32D456D94E8441990E844
45C21790: 00000000000000000000000000000000 E183E8442585E844714D0245DDA12D45
45C217A0: 00000000000000000000000000000000 4D7AE84465112045911120452188E844
;W580 SW-R8BE001
;Moving Track Info bar
;© KrasH
;(p) osiel
+44140000
117B0FA: 111C 0021 ;X-coordinate (Coordinate from the left border)
117B0F8: 0022 4022 ;Y-coordinate (Coordinate from the status bar)
;W580 SW-R8BE001
;Suplement for patch: "Add item Record in Radio"
;Add item "Recorded sounds" for showing your Recorded sounds
;© k790Alex
;(p) anarkes
450F8AA6: 5C4AA069 5C4A9047
450F8C18: 15080000 49B6CB45
45CBB648: 00000000000000000000000000000000 0FB5A0695021244A054B9847A0695021
45CBB658: 00000000000000000000000000000000 06A20132034B98470FBCA069024A00BD
45CBB668: 00000000000000000000000000000000 79173845011738451508000030B5041C
45CBB678: 00000000000000000000000000000000 1A4B9847051C1A4B9847011C281C194B
45CBB688: 00000000000000000000000000000000 9847281C0021184B9847281C0721174B
45CBB698: 00000000000000000000000000000000 9847281C1049164B98471EA1281C154B
45CBB6A8: 00000000000000000000000000000000 98470121281C144B98470121281C134B
45CBB6B8: 00000000000000000000000000000000 98470121281C124B98471121281C114B
45CBB6C8: 00000000000000000000000000000000 98471549281C104B9847281C0F4B9847
45CBB6D8: 00000000000000000000000000000000 281C0F4B984730BD8D1B0000C151EC44
45CBB6E8: 00000000000000000000000000000000 25EB2A45D153EC44D953EC448554EC44
45CBB6F8: 00000000000000000000000000000000 B554EC449D54EC44A554EC445D54EC44
45CBB708: 00000000000000000000000000000000 6554EC448D54EC448153EC44691AEC44
45CBB718: 000000000000000000000000 7552EC4424B7CB4568D7B645
;Load sounds from /usb/music/fm/
45CBB724: 00000000000000000000000000000000 2F007500730062002F006D0075007300
45CBB734: 00000000000000000000000000000000 690063002F0066006D002F000000000
;W580 SW-R8BE001
;Show full text in "View all labels" of "ServiceMenuBook"
;Pressing Key "Show"
;Now, showing label number (DEC) too.
;© k790Alex
;(p) anarkes
;v.1.1
4501A6EA: 1049A0692A1C A0690F498847
4501A72C: C20F0000 D1B5CB45
45CBB5D0: 00000000000000000000000000000000 0FB5A0690449FD22D200044B98470FBC
45CBB5E0: 00000000000000000000000000000000 014903A2013200BDC20F000079173845
45CBB5F0: 00000000000000000000000000000000 30B583B0081C0F4A9047431C02930130
45CBB600: 00000000000000000000000000000000 0D4A904700900FA0062103220B4B9847
45CBB610: 00000000000000000000000000000000 0190684605210322084B9847041C0020
45CBB620: 00000000000000000000000000000000 002103B4211C002200200123044DA847
45CBB630: 00000000000000000000000000000000 05B030BD5DE431458171344535743445
45CBB640: 0000000000000000 7D982B453A0A0A00
;W580 SW-R8BE001
;MiniGPS v1.0
;Position determination by BS number
;Create a folder "/ tpa / user / other / ini /" (without the quotes)
;In the newly created folder put minigps.ini
;About .ini file
;[LogFolder] : Path to the folder with logs. Folder must be created beforhand. "/" At the end -
is required.
;Log contains time and BS number if BS changed. If you do not need to keep logs - remove this line
from the ini file.
;(c) Hussein
;(p) c368511
45BAB8B0: 2B00000000000000 070000004FC6BF45
45BFC530: 00000000000000000000000000000000 F0B5D4B000270C1C7C4D2968EB791B02
45BFC540: 00000000000000000000000000000000 2E7A1E43A068884203D1E068B04200D1
45BFC550: 00000000000000000000000000000000 75E0A160E660321C2B6879A1684600F0
45BFC560: 00000000000000000000000000000000 B6F8206900280ED0002269465B4B9847
45BFC570: 00000000000000000000000000000000 071C08D0011C68465D4B98476A4A0021
45BFC580: 00000000000000000000000000000000 574B984704E0684A06216846544B9847
45BFC590: 00000000000000000000000000000000 061C544988476660206900284AD00022
45BFC5A0: 00000000000000000000000000000000 6FA14E4B9847051C44D00CA961A04E4A
45BFC5B0: 00000000000000000000000000000000 90470CAEF17802B4B378328863A103A8
45BFC5C0: 00000000000000000000000000000000 00F085F801B081A00090002F00D00097
45BFC5D0: 00000000000000000000000000000000 14A800210160291C444B984702A9434B
45BFC5E0: 00000000000000000000000000000000 9847011CA0206844414B984752A1424B
45BFC5F0: 00000000000000000000000000000000 98470190002819D0009AA168E06807B4
45BFC600: 00000000000000000000000000000000 7379327959A1EC20684400F060F803B0
45BFC610: 00000000000000000000000000000000 E0206844374B9847019B011C0122E020
45BFC620: 00000000000000000000000000000000 6844364EB0470198364B9847291C0020
45BFC630: 00000000000000000000000000000000 364A9047391C02D00020344A90473C49
45BFC640: 00000000000000000000000000000000 221C7D20C000324B984754B0F0BDF0B5
45BFC650: 00000000000000000000000000000000 C0B030488047002837D0052301221421
45BFC660: 00000000000000000000000000000000 0020294DA847041C142200212A4B9847
45BFC670: 00000000000000000000000000000000 2C4860600020009043A16846274B9847
45BFC680: 00000000000000000000000000000000 4CA1264B98472DA11B4B9847051C16D0
45BFC690: 00000000000000000000000000000000 3DA048A16A46224EB04700280CD10523
45BFC6A0: 00000000000000000000000000000000 01220299491C0020174EB04720610299
45BFC6B0: 00000000000000000000000000000000 2B1C0122124EB047281C124B98471C49
45BFC6C0: 00000000000000000000000000000000 221C7D20C000124B984740B0F0BD08B4
45BFC6D0: 00000000000000000000000000000000 014B9C4608BC60477970554499CB2745
45BFC6E0: 00000000000000000000000000000000 35743445ED362C453198D444ED735544
45BFC6F0: 00000000000000000000000000000000 9190E444817455441D381B45C9311B45
45BFC700: 00000000000000000000000000000000 CD301B45792E1B4551DCEB447DDCEB44
45BFC710: 00000000000000000000000000000000 05B42A45351A2C4594300020F17C5544
45BFC720: 00000000000000000000000000000000 E183E844FFFFFF6FFFFF000000EC1820
45BFC730: 00000000000000000000000000000000 31C5BF4500000000612B000072620000
45BFC740: 00000000000000000000000000000000 5B253034583A253034585D0025303264
45BFC750: 00000000000000000000000000000000 2D253032642D253032642E7478740000
45BFC760: 00000000000000000000000000000000 5B4C6F67466F6C6465725D0025303264
45BFC770: 00000000000000000000000000000000 3A25303264202D205B253034583A2530
45BFC780: 00000000000000000000000000000000 34585D2025730A002F00740070006100
45BFC790: 00000000000000000000000000000000 2F0075007300650072002F006F007400
45BFC7A0: 00000000000000000000000000000000 6800650072002F0069006E0069002F00
45BFC7B0: 00000000000000000000000000000000 000000006D0069006E00690067007000
45BFC7C0: 00000000000000000000000000000000 73002E0069006E00690000004E6F6E65
45BFC7D0: 00 00
;W580 R8BE001
;Full screen Walkman
;(c)Therion
44F36940: 9610 1123
44F36950: 9110 1123
44F36958: BB10 1123
44F3BD52: 0221 0421
44F3BF42: 0221 0421
44F31EA6: 0221 0421
44F32750: 8A020000 9E070000
452419F8: 2989201CFFF7E2FD 004B18478B19C245
45242E98: 3068012521F1FCFF 004B1847A919C245
44F3A794: 3068022112F1B8FE 004B1847651AC245
4523F9A0: 68680921DFF0D4F8 004B1847411AC245
44F35A04: 0021201C78F390FE 004B1847211AC245
45239AEA: 38680121E4F0BDFF3868 014B1847C046C119C245
4523B66E: 38680121E3F0FBF93868 014B1847C046E119C245
4523EF7A: 2068DFF0F2FD206825F1 014B1847C046011AC245
45C2198A: 00000000000000000000000000000000 04212868394B98472989201C034B9847
45C2199A: 00000000000000000000000000000000 2868004B1847031A2445C51524453068
45C219AA: 00000000000000000000000000000000 0421314B9847306801252A4B9847004B
45C219BA: 00000000000000000000000000000000 1847A12E244538680121054B98473868
45C219CA: 00000000000000000000000000000000 0421294B98473868014B1847FFFFF59A
45C219DA: 00000000000000000000000000000000 23456DEA314538680121044B98473868
45C219EA: 00000000000000000000000000000000 0421214B98473868024B1847FFFF6DEA
45C219FA: 00000000000000000000000000000000 314579B623452068054B984704212068
45C21A0A: 00000000000000000000000000000000 1A4B98472068134B9847014B184765EB
45C21A1A: 00000000000000000000000000000000 314587EF23450421201C134B98470021
45C21A2A: 00000000000000000000000000000000 201C024B98470125024B1847FFFF2DE7
45C21A3A: 00000000000000000000000000000000 2A450F5AF34468680921044B98470421
45C21A4A: 00000000000000000000000000000000 6868094B98476868024B1847FFFF51EB
45C21A5A: 00000000000000000000000000000000 3145ABF92345994E364530680421024B
45C21A6A: 0000000000000000000000000000 9847004B18479DA7F344E94E3645
;W580 SW-R8BE001-GENERIC
;Remove SIM-Lock
;(c) IronMaster
;(p) Remove SIM-lock patch generator v2.2
+44140000
4F2114: 30B5041C00231A1C111C1C208CF4 F0B505213A2293F4EFFA0020F0BD
Edited by not found, 10 November 2017 - 15:11.
